I assume its something simple but i cant seem to put my finger on it.
Have one of those kaku door bells. When it rings i get:
19-4-2012 17:49:28 - RFXCOM - (RecRxChar) receiver #1 packet: 2030CF58A7
19-4-2012 17:49:29 - RFXCOM - (RecRxChar) receiver #1 packet: 2030CF7887
19-4-2012 17:49:29 - RFXCOM - (RecRxChar) receiver #1 packet: 2030CF58A7
If i put it in debug mode. But then i go to homeseer to rfxcom plugin, try and click on add it says "No devices found to add!"
Also checked in the virtual (you never know) but nothing.
I would think it would show up their no? This used to work and i didn't change a setting i just moved XP to Win7..
Also see that my other kaku (light sensor) doens't respond, so it looks like a kaku thing, rfxmeter and oregon sensor do come in normally.
I've set in the interfaces tab all the items to : Y Y Y Y Y Y Y , should be ok i suppose. I even removed them all and added them all to make sure they are set, didn't help.
So tell me which silly thing did i forget
Kaku not showing up in homeseer
Moderator: b_weijenberg
- Snelvuur
- Forum Moderator
- Contact:
- b_weijenberg
- Forum Moderator
Re: Kaku not showing up in homeseer
Configure house code P on the RFXCOM - X10 page to Status Only.
Enable X10 recive in the receiver configuration.
Create device P8 on the Homeseer status page and it displays the status of the push button
- Snelvuur
- Forum Moderator
- Contact:
It comes in as P16, i assume the ligth sensor is different then the doorbel thinigy. Since i had that one in the past via the normal routine. "Kaku AC Input Device AC[6278889]a" anyway i know where to look now, just been a while since i used that one thanks. And indeed silly mistake of me
