YouLess LS110 Energy Monitor
Re: YouLess LS110 Energy Monitor
Create two new virtual devices on the status page.
Copy complete script above.
Create an event, recurring, i.e: every 60 seconds
Add Action: run script
Create new one.
Name: i.e: Youless.vb
Open script window
Paste complete script and change ip address and both device codes A8 and A9 two new device codes you earlier created.
Create new one.
Open script window
- Starting Member
I assumed a fixed length for the total energy usage and it showed Wh instead of kWh, mine is just turned on since yesterday so I have very low kWh number. Here is an updated version that I think should solve it and also display the value in kWh.Rutger wrote:Hi Yellowbird,
Thnx for your script.
My counter have 3 digits behind the komma.
The youless counter is on 29661,544 kWh.
In Homeseer I see the value 296615. Your script have the komma 1 place too far to the right?
Do you have the same experience?
Imports System.Net
Sub Main(parm as object)
Dim strUrl As String = "http://192.168.1.230/a?f="
Dim devIdCurrent As String = "A8"
Dim devIdTotal As String = "A9"
Dim request As WebRequest = WebRequest.Create(strUrl)
Dim response As WebResponse = request.GetResponse()
Dim data as String = new System.IO.StreamReader(response.GetResponseStream()).ReadToEnd()
Dim s1 As Integer
Dim e1 As Integer
Dim current As Integer
Dim total As Double
s1 = data.IndexOf("pwr") + 5
e1 = data.IndexOf(",", s1)
current = Convert.ToInt32(data.SubString(s1,e1 - s1))
hs.SetDeviceValue(devIdCurrent, current)
hs.setdevicestring(devIdCurrent, current.ToString() & "W")
s1 = data.IndexOf("cnt") + 6
e1 = data.IndexOf("pwr", s1) - 3
total = Convert.ToDouble(data.SubString(s1,7).Replace(",",""))/1000
hs.SetDeviceValue(devIdTotal , total)
hs.setdevicestring(devIdTotal , total.ToString() & "kWh")
End Sub
How do i configure the virtual devices?
On your status page where all devices are visible, click on the left top on 'add device' and configure as you can see in the screenshot. Room and Floor will be different ofcourse.
No other configuration is necessarry. For the Youless script from Yellowbird, you'll have to add two virtual devices, like YL_Current and YL_Total.
The devicevalue and devicestatus will be updated when the script runs.
- newdevice.jpg (37.23 KiB) Viewed 31276 times
Trying to get this script back to work after an stupid delete action...
Created an event with the following script:
Created two "Status only" devices Y1 and Y2 for the values. When I run the script my HS log says:
Running script, script run or compile error in file: GetPwr1006:Expected ')' in line 3 More info: Expected ')'
Overlooked the script now like 10 times but can't find this fault?
Imports System.Net
Sub Main (parm as Object)
Dim strUrl As String = "http://192.168.1.9/a?f="
Dim devIdCurrent As String = "Y1"
Dim devIdTotal As String = "Y2"
Dim data As String = new System.IO.StreamReader(response.GetResponseStream()).ReadToEnd()
Dim s1 As Integer
Dim e1 As Integer
Dim total As Double
End Sub
Ah ja het truukje was opslaan als .vb...
De code bevat nog een foutje volgens mij. Je pakt de substring fixed 7 lang bij het totaal gebruik. Dit zou e1 - s1 moeten zijn om de lengte van de string te krijgen...
En voor degenen die deze code gebruiken, niet vergeten:
Groet,
Nika.
Imports System.Net
Dim devIdCurrent As String = "v4"
Dim devIdTotal As String = "v5"
Dim s1 As Integer
Dim e1 As Integer
Dim total As Double
hs.setdevicestring(devIdCurrent, current.ToString() & " Watt")
total = Convert.ToDouble(data.SubString(s1,e1 - s1).Replace(",",""))/1000
hs.setdevicestring(devIdTotal , total.ToString() & " kWh")
End Sub
- virtual devices aanmaken voor current en total
- ip adres veranderen in youless ip-adres (192.168.1.9 vervangen)
- v1 en v2 veranderen in de codes van jouw virtual devices
- script plaatsen in scripts folder
- event aanmaken dat script iedere X minuten runt
- advies: zorg ervoor dat het event niet logt, anders heb je bij iedere execute een regel dat hij het script start
Groet,
Nika.
- 7. Event Trigger.png (13.94 KiB) Viewed 31225 times
- 6. Event Properties.png (20.02 KiB) Viewed 31225 times
- 5. Virtual Device YouLess Total Options.png (16.53 KiB) Viewed 31225 times
- 4. Virtual Device YouLess Total Config.png (14.56 KiB) Viewed 31225 times
- 3. Virtual Device YouLess Current Options.png (13.29 KiB) Viewed 31225 times
- 2. Virtual Device YouLess Current Config.png (20.57 KiB) Viewed 31225 times
I just added this script to my HomeSeer and it is working fine
I also use two scripts to create a day usage counter (script was used for the NorthQ before, maybe it it not completely working due to DeviceString versus DeviceValue issues)
This one copies the current usage to another virtual device (running at 23:59)
This one calculates the usage of the last 24 hours using the value saved in the day before (running at 23:54)
My devices are
hs.SetDeviceString("K74", hs.DeviceString("K76") )
hs.SetDeviceLastChange("K74",now)
End Sub
hs.SetDeviceString("K73", CStr( hs.DeviceValue("K76") - hs.DeviceString("K74") ) /100 )
hs.SetDeviceLastChange("K73",now)
End Sub
My devices are
YouLess_Total_Day_Usage 0 Beganegrond Meterkast YouLess_Total_Day_Usage K73 Status Only Today 23:05:50
Youless_Total_Yesterday 39825,715 kWh Beganegrond Meterkast Youless_Total_Yesterday K74 Status Only Today 23:06:55
YouLess Current 696 Watt Beganegrond Meterkast YouLess Current K75 Status Only Today 23:12:26
YouLess Total 39825,786 kWh Beganegrond Meterkast YouLess Total K76 Status Only Today 22:52:26
Made some changes to get the script ready for HomeSeer 3:
Using the Reference ID to point to the virtual devices, don't know what to use to get it working with the Technology Address attribute?
Imports System.Net
Dim strUrl As String = "http://192.168.1.14/a?f="
Dim devIdCurrent As String = "117"
Dim devIdTotal As String = "120"
Dim s1 As Integer
Dim e1 As Integer
Dim total As Double
hs.SetDeviceString(devIdCurrent, current & " Watt", True)
hs.SetDeviceString(devIdTotal , total & " kWh", True)
End Sub
I migrated to HS3 and these are my YouLess Scripts the last one is working fine now the other two in need to verify
These are the scripts
Maak_Nachtstand_Youless.vb
Maak_Verbruik_Youless.vb
youless_update_HS3.vb
hs.SetDeviceValue("449", hs.DeviceValue("448") )
hs.SetDeviceLastChange("449",now)
End Sub
hs.SetDeviceValue("450", CStr( hs.DeviceValue("448") - hs.DeviceValue("449") ) )
hs.SetDeviceLastChange("450",now)
End Sub
Imports System.Net
Dim strUrl As String = "http://192.168.140.150/a?f="
Dim devIdCurrent As String = "447"
Dim devIdTotal As String = "448"
Dim s1 As Integer
Dim e1 As Integer
Dim total As Double
End Sub
Is there somebody with a little more scripting experience who can fix the first two scripts for me. I want to create a value each night around 23:59 and extract the next night value from it to get a day usage of the last day
This is an old topic but i am totally new to Homeseer and i have a problem with this script.
It all works but when i want to log the data for example to use in Jon00 database or in Imperihome or in Device history, nothing will be logged.
I think the problem is that there is coming no data in the Value field , only in the "string" field, and the plugins get the data from the Value.
Is this possible to change something in this script?
Homeseer 3 on andere Intel Nuc/Win10
Plugins Imperihome Jowihue Rfxcom Pushover P1
RFXcom V3 Visonic Powermax+ some KaKu
The device string is set correctly, but the value is indeed empty. Just a small change in the syntax.I think the problem is that there is coming no data in the Value field , only in the "string" field, and the plugins get the data from the Value.
Edit this:
to
hs.SetDeviceValueByRef(devIdCurrent, current, true)
and
to
hs.SetDeviceValueByRef(devIdTotal , total, true)
HS3 Pro 3.0.0.298, W10 on Atom x5-Z8300
SqueezeBox, UltraM1G3, UltraMon3, Z-Wave
HS2 Pro 2.5.0.80, W2k3 on AMD X2
X10 CM11A/CM12U, SqueezeB, UltraMon, tenHsPower, UltraM1G, SqueezeBox
Hi there,
This is my script that I use to have current and total kWh values in Homeseer 3.
Is there anybody who have added also his gas meter reading in HS3 with a Youless monitor and is willing to share his script for this?
Maybe some other scripts for HS3 like last day usage / current day usage that are used are welcome as well
Daan
Daan
