Thinking Cleaner HS3 Script (roomba wifi Control)
bartbakels
Post by bartbakels »
Dear all,
Hereby my my HS3 script for getting the roomba status and controlling the roomba via a Thinking cleaner WIFI module in Homeseer 3;
devices
devices
thinking cleaner devices.png (68.3 KiB) Viewed 7307 times
dropbox.com/s/ogjvd86oyd9uq2u/thinking% ... 2.zip?dl=0
Installation instructions:
Unzip the zip file in the homeseer 3 root folder.
- It creates the script (thinking cleaner.vb) in the scripts directory
- thinking cleaner script images in the html folder
- json deserialisation dll in root
Also add this entry to ScriptingReferences in the homeseer settings.ini;
Newtonsoft.Json;Newtonsoft.Json.dll
Restart Homeseer 3 and add a recurring event to trigger the script every x minutes.
recurring event
recurring event
recurring event.png (24.69 KiB) Viewed 7307 times
The script will automatically create the devices, which display the roomba status and also creates buttons to dock, en start cleaning. The script can also triggered with parameters to execute these commands. (Dock, Clean, Cleanmax)
event clean.png (26.93 KiB) Viewed 7307 times
Please comment and or request improvements in this thread
known Limitations;
- Only support one thinking cleaner module for now
- error handling need improvement
Regards
Bart
(ON ESXI )on NUC
RdP
Re: Thinking Cleaner HS3 Script (roomba wifi Control)
Post by RdP »
Hi Bart,
Looks great !!
I had a slightly different approach... But maybe yours is better (especially voor HStouch)
My plugin creates just 1 HS device instead of different ones for several statuses.
See screenshot. I will submit the plugin to HS, this will take a while. :cry:
bartbakels
Rien,
Yeah that was the idea to represent them in Hstouch. I probabaly will add other stausses and commands also, but was a bit in a hurry.
But maybe you could reconsider added the devices with statusses in a group? I prefer the use of a plugin above the use of scripts :oops:, your solution looks great as well.
Regards
Bart
(ON ESXI )on NUC
