New Toon firmware 5.13.12
Eneco (or Quby) released toon firmware 5.13.9. They state that there are no changes except of 'auto update'.
In fact there are a few changes internally, related to a future where the VPN isn't used anymore and where the Toon will connect (probably) to a cloud service center (instead of over the VPN).
But for now this feature isn't enabled yet in 5.13.9.
Also for the Toon2 in 5.13.9 there is support for the CO2 and particale sensor. But also this feature isn't enabled yet.
But I haven't found any evidence for a auto-update feature. As I understand this auto-update will be enabled in their update script and this is not related to the firmware 5.13.9. For now this auto-update is only enabled for TST and ACC toon's only in the eneco official update script, no production toons. If auto-update will be enabled, this will never work on rooted toons as long as the VPN is disabled. Maybe they will enabled download updates over the internet also in the future (instead of VPN). But at that time we will probably have blocked that also
Updating your rooted toon, with the TSC update script or using the 'check update button' in the TSC menu, is now supported to 5.13.9. There is however, for now, no reason to update.
Re: New Toon firmware 5.13.9
Okay,
thanks for your information.
Eneco just halted 5.13.9 for unknown reasons (https://forum.eneco.nl/software-en-hard ... post221834) so I removed 5.13.9 from the update-script as a valid update also.
Is it wise to downgrade back to the previous version?
__________________
No. Just stick with 5.13.9. I think it is just related to some issue's with there remote mobile app and this new version
Re: New Toon firmware 5.13.12
Eneco just launched 5.13.12 as a fix for RRD issue's in 5.13.9.
This new version is now available for rooted toons also using the update script or the check update button in the TSC menu. Have fun! (though nothing visible changed ... )
Thanks, it was my first update on rooted toon1
I updated it within tsc menu, all is working fine with the new firmware
I was trying to update my toon, but it failed the disk was full of my toon, lucky it boot up again.
Is it okay to delete these files in /var/volatile/tmp
.ash_history.26178
.ash_history.29841
actualBuienradarTemp.txt
fb0_blank
happ_weather
hcb_log
lighttpd_error.log
opkg-killed-reason
2824192 Sep 28 14:33 resources-qb2-5.9.6.zip
update.status.vars
wasteDateIcon.txt
wasteDateIcon2.txt
wasteDates.txt
wpa_ctrl_686-2
www-cache
Filesystem Type Size Used Available Use% Mounted on
ubi0:rootfs ubifs 103.3M 85.0M 18.3M 82% /
tmpfs tmpfs 61.6M 2.9M 58.7M 5% /var/volatile
Or do I need to delete some apps, is not match installed.
0 HCBv2
4.0K backup
764.0K bin
0 boot
0 configured
0 dev
1.1M etc
4.6M lib
0 linuxrc
26.8M mnt
du: proc/27211: No such file or directory
0 proc
39.1M qmf
132.0K root
892.0K sbin
14.4M squish
0 sys
0 tmp
28.0K update-script
72.5M usr
3.7M var
.ash_history.26178
.ash_history.29841
fb0_blank
happ_weather
hcb_log
lighttpd_error.log
opkg-killed-reason
update.status.vars
wasteDateIcon.txt
wasteDateIcon2.txt
wasteDates.txt
wpa_ctrl_686-2
www-cache
0 HCBv2
4.0K backup
764.0K bin
0 boot
0 configured
0 dev
1.1M etc
4.6M lib
0 linuxrc
26.8M mnt
0 proc
39.1M qmf
132.0K root
892.0K sbin
14.4M squish
0 sys
0 tmp
28.0K update-script
72.5M usr
3.7M var
That is just a volatile location cleared at reboot.michel30 wrote:I was trying to update my toon, but it failed the disk was full of my toon, lucky it boot up again.
But from what version did you update from? Disk full is only known to happen from 3.x or 4.x to 5.x, but we force you to update to 5.0.4 first. Can you share your /mnt/data/update/upgrade-qb2.sh.log ?
My toon is running on 5.9.6 and this is the log file:
Otherwise I will do a reboot and try again.
>> 2019-10-06 13:14:21 +0000 (pid 24642) upgrade-qb2.sh qb2 uni 5.13.12 prepare
>> 2019-10-06 13:14:21 +0000 (pid 24642) prepare
>> 2019-10-06 13:14:23 +0000 (pid 24642) preparing
>> logKeyValText: key(upgrade-prep-info), value(upgrade-prep-start) and text(afv=qb2/uni/5.13.12)
>> Hotfix for writing System Time to RTC
Hardware Clock before: Sun Oct 6 13:13:17 2019 0.000000 seconds
Hardware Clock after : Sun Oct 6 13:14:23 2019 0.000000 seconds
>> configured opkg feeds:
src/gz base http://feed.hae.int/feeds/qb2/uni/5.13.12
src/gz oe-2.6.36-R10-h28-cmpxchg64 http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/2.6.36-R10-h28-cmpxchg64
src/gz oe-2.6.36-base-r17-splash2 http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/2.6.36-base-r17-splash2
src/gz oe-all http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/all
src/gz oe-armv5e http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/armv5e
>> opkg_dl.update: opkg --cache /mnt/data/update --download-only update # try 1/5
>> opkg_dl.update.supervisor: monitoring /mnt/data/update for threshold 5000
Downloading http://feed.hae.int/feeds/qb2/uni/5.13.12/Packages.gz.
Inflating http://feed.hae.int/feeds/qb2/uni/5.13.12/Packages.gz.
Updated list of available packages in /var/lib/opkg/base.
Downloading http://feed.hae.int/feeds/qb2/uni/5.13.12/Packages.sig.
Signature check passed.
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/2.6.36-R10-h28-cmpxchg64/Packages.gz.
Inflating http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/2.6.36-R10-h28-cmpxchg64/Packages.gz.
Updated list of available packages in /var/lib/opkg/oe-2.6.36-R10-h28-cmpxchg64.
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/2.6.36-R10-h28-cmpxchg64/Packages.sig.
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/2.6.36-base-r17-splash2/Packages.gz.
Inflating http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/2.6.36-base-r17-splash2/Packages.gz.
Updated list of available packages in /var/lib/opkg/oe-2.6.36-base-r17-splash2.
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/2.6.36-base-r17-splash2/Packages.sig.
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/all/Packages.gz.
Inflating http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/all/Packages.gz.
Updated list of available packages in /var/lib/opkg/oe-all.
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/all/Packages.sig.
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/armv5e/Packages.gz.
Inflating http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/armv5e/Packages.gz.
Updated list of available packages in /var/lib/opkg/oe-armv5e.
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.4.9-master-libuuid/armv5e/Packages.sig.
> opkg_dl.update: Exit code: 0
>> opkg_dl.download: opkg --cache /mnt/data/update --download-only upgrade # try 1/5
>> opkg_dl.download.supervisor: monitoring /mnt/data/update for threshold 5000
> opkg_dl.update.supervisor: Exit
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/happ-pwrusage_1.834-1-g40f0-fix-EI-722-graphs-wrong-for-single-tariff-customers_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/hcb-netcon_1.531-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/happ-kpi_1.549-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/happ-pwrusage_1.834-1-g40f0-fix-EI-722-graphs-wrong-for-single-tariff-customers_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/hcb-rrd_2.222-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/libuuid1_2.25.2-r1-q1_armv5e.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/tzdata_2011b-r8.0_all.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/firmware-ma_1.155-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/qmf-release_1.1376-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/qt-gui_1.9691-fix-5-13-hotfixes_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/tenant-eneco-nl_1.155-master_all.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/qt-gui_1.9691-fix-5-13-hotfixes_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-dJJujT/hcb-bxtproxy_1.1365-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: Disk space check failed! (4872 < 5000) Aborting download!
Killed
> opkg_dl.download: Exit code: 137
sh: can't kill pid 24807: No such process
>> Disk space check killed opkg! (/tmp/opkg-killed-reason:out-of-disk-space)
> Performing extra cleanup actions
+ rm -rf /mnt/data/update/firmware-ma_1.155-master_qb2.ipk /mnt/data/update/firmware-zwave-ctrlr_1.48-master_qb2.ipk /mnt/data/update/happ-kpi_1.549-master_qb2.ipk /mnt/data/update/happ-pwrusage_1.834-1-g40f0-fix-EI-722-graphs-wrong-for-single-tariff-customers_qb2.ipk /mnt/data/update/hcb-bxtproxy_1.1365-master_qb2.ipk /mnt/data/update/hcb-netcon_1.531-master_qb2.ipk /mnt/data/update/hcb-rrd_2.222-master_qb2.ipk /mnt/data/update/libuuid1_2.25.2-r1-q1_armv5e.ipk /mnt/data/update/qmf-release_1.1376-master_qb2.ipk /mnt/data/update/qt-gui_1.9691-fix-5-13-hotfixes_qb2.ipk /mnt/data/update/tenant-eneco-nl_1.155-master_all.ipk /mnt/data/update/tzdata_2011b-r8.0_all.ipk /tmp/opkg-dJJujT
+ du -h /mnt/data/update/updated-rooted.status /mnt/data/update/upgrade-qb2.sh /mnt/data/update/upgrade-qb2.sh.log /mnt/data/update/upgrade-qb2.sh.res
4.0K /mnt/data/update/updated-rooted.status
36.0K /mnt/data/update/upgrade-qb2.sh
720.0K /mnt/data/update/upgrade-qb2.sh.log
4.0K /mnt/data/update/upgrade-qb2.sh.res
+ find /mnt/data/update -name _opkg.*.script.* ! -name upgrade-qb2.sh*
+ xargs -r -t rm -f
+ set +x
>> logKeyValText: key(upgrade-error-disk-space-report), value({"log":6040,"config":240,"rrd":20324}) and text({"fromVersion":"5.9.6","toVersion":"5.13.12"})
>> logKeyValText: key(upgrade-exit-status), value(prepare-error-opkg-download-out-of-disk-space) and text({"fromVersion":"5.9.6","toVersion":"5.13.12"})
>> 2019-10-06 13:18:20 +0000 (pid 24642) prepare-error-opkg-download-out-of-disk-space 'Not enough disk space to download required packages!'
Yes because you still have 18% free according to your previous post but the eneco script (their script, not mine) failed uppon downloading package files for 'out of space''. Think it was just a glitch.michel30 wrote: Otherwise I will do a reboot and try again.
First though, just to be sure, remove all files in /mnt/data/update and then reboot.
This only contains the already downloaded files and logs. Those are safe to remove.
It is now running on 5.13.12 thanks again for your help.
- Starting Member
When I came home today, Toon showed a message about updating to 5.13.12. So I just let it. But it failed, and here's the log:
Sooooo....
Version: 3.9951 - TheHogNL & TerrorSource & yjb - 3-10-2019
If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
Unattended mode
You are currently running version 5.9.6 on a qb2 with flavour uni
Available versions: 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.15 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.11.6 4.12.0 4.13.6 4.13.7 4.15.2 4.15.6 4.16.8 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4 5.0.5 5.0.6 5.2.11 5.5.7 5.9.6 5.13.9 5.13.12
Unattended selected version 5.13.12
Alright, I will try to upgrade to 5.13.12
Warning: upgrade script from Eneco server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)?
- Administrator
Can you check the logfile in /mnt/data/update/ for possible errors?Blacky's Boss wrote:When I came home today, Toon showed a message about updating to 5.13.12. So I just let it. But it failed, and here's the log:
Sooooo....Code: Select all
=================================================================================================================================================================== Welcome to the rooted Toon upgrade script. This script will try to upgrade your Toon using your original connection with Eneco. It will start the VPN if necessary. Please be advised that running this script is at your own risk! Version: 3.9951 - TheHogNL & TerrorSource & yjb - 3-10-2019 If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more. https://paypal.me/pools/c/8bU3eQp1Jt =================================================================================================================================================================== Unattended mode You are currently running version 5.9.6 on a qb2 with flavour uni Available versions: 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.15 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.11.6 4.12.0 4.13.6 4.13.7 4.15.2 4.15.6 4.16.8 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4 5.0.5 5.0.6 5.2.11 5.5.7 5.9.6 5.13.9 5.13.12 Unattended selected version 5.13.12 Alright, I will try to upgrade to 5.13.12 Now starting the VPN tunnel and waiting for it to be alive and configured... Now starting the VPN tunnel and waiting for it to be alive and configured... Tunnel is alive and configured. Warning: upgrade script from Eneco server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)? Quitting the upgrade. It was a nice try tho...
The problem is here: Warning: upgrade script from Eneco server is changed.TerrorSource wrote: Can you check the logfile in /mnt/data/update/ for possible errors?
I'll check this new update and acknowledge it if it is ok.
