Hello, an question:
Is it possible that one of the technical guys makes an app to control the 'Moode Audio' ?
Thats an alternative to the 'Volumio', in my opinion a more stable program for the Raspberry Pi.
See:
https://moodeaudio.org/
And:
https://github.com/moode-player/moode/b ... /setup.txt
I volunteer as an tester
Moode Audio controller
Re: Moode Audio controller
Maybe ik you can post a full list of the rest api urls of moode like :
http:// moode/command/?cmd=play
http:// moode/command/?cmd=pause
http:// moode/command/?cmd=next
http:// moode/command/?cmd=previous
Please find the urls needed in the volumio app:
https://raw.githubusercontent.com/ToonS ... erTile.qml
And
The url to get all info from the mood (in volumio it is api/v1/getState)
And
Thanks.
Do you mean that i have to give you the output of this commands?
On this website (i think) most of the commands are mentioned: https://github.com/moode-player/moode/b ... /setup.txt
AND
https://github.com/moode-player/docs/bl ... 20guide.md
But i want to test everyting, so if i can do anyting let me know (also via PM)
AND
no, i have send two links of the volumio controller app. In that app there are urls's to controla and read the volumia controlller. I need to receive the urls's to control the Moode controller. So please try to find them and post them here. It is undoable to read all information on Moode.
Okay, i will send an PM thats easier i think.
I see you can use moode.local (in stead of local ip).
This commands:
http://moode.local/command/playback.php ... mpd_status
Gives this output:
{"volume":"54","repeat":"0","random":"0","single":"0","consume":"0","partition":"default","playlist":"340","playlistlength":"84","mixrampdb":"0","state":"play","song":"2","songid":"3","time":"0","elapsed":"5903","bitrate":"128 kbps","audio":"44100:24:2","nextsong":"3","nextsongid":"4","song_percent":"0","audio_sample_rate":"44.1","audio_sample_depth":"24","audio_channels":"Stereo"}
Thats a start :- )
This commands:
Gives this output:
Thats a start :- )
Is there somebody who can help with this app? I have a few working commands so i think its possible
Nobody?
For all Volumio users....Moode Audio is much more stable
