Does anyone know a Serial Port Monitor that can be used with the Belkin LAN USB Hub ???
I need one Thanks!
Serial Port Monitor
Re: Serial Port Monitor
The belkin will just create a virtual usb port right? And a connected USB stick will just create a virtual com port.. which you then can use as a normal com port (?)
I use this one: http://www.aggsoft.com/serial-port-monitor.htm
Yes it creates a virtual port; the monitor i always use doesn't see it... that's why i asked.
Serial Port Monitor has been updated some time ago. The history list shows that they have fixed a bug/problem with port detection.
Helen
Helen
