RFX Charts in HomeSeer Touch?
Has anyone tried to get RFX Charts to display in HomeSeer Touch?
Did it work and how?
Cheers
DJ
Cheers
DJ
Re: RFX Charts in HomeSeer Touch?
strange? I deleted them.
I guess DJ has an automatic topic creater in his HA system
Hi DJ,
I'm just trying to get the same issue solved.
If you use this command in an event:
hs.URLAction("http://192.168.1.10:81/RFXCharts/WeightO.aspx","GET","","")
four png files are stored in html\rfxcharts\charttemp
It should also be possible to change the aspx files in RFXUSER but I didn't get that far.
Herbus (Jos)
Strange! I only submitted the msg once..
Well, what Herbus suggested is actually what I was looking for. I can schedule an event that creates new charts so I can use these in HST.
Thank you!
DJ
Thank you!
DJ
The RFX Chart scripts located in RFXUSER can be modified pretty easily. NOTE: This doesn't change the charts generated in the ChartTemp directory!
Problem:
SOLUTION: copy the netchartdir.dll and .xml file to the \html\bin directory (xml file might not be required)
File modified: RFXUtility.aspx
Lines removed (by prefixing them with a single quote ' )
Change chart size
replace
New XYChart(880, 300
with
New XYChart(600, 300
Cheers
DJ
Problem:
Could not load file or assembly 'netchartdir' or one of its dependencies. The system cannot find the file specified.
'.addText(800, 30, "Version: " & swversion)
'.addLegend(620, 50, False)
'.addText(620, 200, "Totals last 24 hours:", "bold", 10)
'.addText(640, 220, "Cost : " & FormatCurrency(kwhcostdata, 2))
'.addText(640, 240, "Power: " & CStr(Math.Round(kwhtotaluse, 2)) & " kWh")
replace
with
Cheers
DJ
Hi DJ,
It's quite easy to change the aspx files. Thanks for sharing. How are the results on your touchscreen?
Do you use the url to the aspx page in HST or were you able to export a png file?
Tnx
Tnx
Herbus (Jos)
In which map can we find the RFXUtility.aspx?
Is this still the same file to modified?
B.R. Wim
B.R. Wim
- b_weijenberg
C:\Program Files (x86)\HomeSeer HS2\html\RFXUSER is the directory with aspx files
In that map is standing RFXUtility24h.aspx and RFXUtility365d.aspx.
And what is the neccessary URL?
B.R. Wim
B.R. Wim
Last weekend I tried again to make a copy of the RFX charts to Homeseer touch. I can't clear that. Is there someone who can help me, how to do this?
Also if I make a URL to a fixed picture, in HStouch the new picture will not arrive. Has someone a solution for this problem.
B.R. Wim
B.R. Wim
I found a solution for bring the RFX charts into HStouch.
Use the next url for a chart into a imagebox::
http://192.168.2.37:81/RFXCharts/ChartTemp/wh01.png
In the folder ChartTemp are more png-files which give the total weather report from RFXcom.
Refreshing is possible after calling the page again.
B.R. Wim
B.R. Wim
