I'm considering to buy the KAKU TPC-300 to simulate light scenes while nobody is at home. Has anyone experience with this unit?
@Administrator; I noticed the TPC-300 manual http://www.klikaanklikuit.nl/downloads.asp is not listed under Files\Manuals\Kaku, maybe you can add it?
KAKU TPC-300 usb timer experiences
Kind regards, Rob.
Re: KAKU TPC-300 usb timer experiences
I guess people here have no experience with this unit because it is a one-way controller (send only) and therefore not really 'domotica'...
Kind regards, Rob.
Yes, i did an implementation at my neighbors so far after 2 months it works well .. the main application is to switch outdoor lightning based on sun up and set timing.
Also you can switch indoor lights easily simulating living activities. sure some limitations but the price is right
Check Internet ... i got the unit for E60 including transportation cost ...
Henk
Henk
The unit is normally 79 excl shipment so thanks for the hint, for sure I will check the internet for a better price...
Kind regards, Rob.
- Jeroen Bartels
Why is one way transmission no Domotica? I agree 2 way is nicer but I have many kaku devices that work really well.I guess people here have no experience with this unit because it is a one-way controller (send only) and therefore not really 'domotica'...
**Jeroen**
Of coarse I'm only referring to the TPC-300 so let me rephrase. ''As a one-way central control unit this is not really domotica"...
Kind regards, Rob.
@Henk; thanks for that link, I will check it out!
Kind regards, Rob.
