Updating Plugin for newer firmwares
Moderator: RdP
Yep, I've started working on the HS2 version of the Fritz!Box plugin so that it will also work with newer firmware versions.
But what I've seen until now, doesn't make me happy... a lot of work (to be done)!
This afternoon I updated my own Fritz so I could test a bit more before sending a beta to some beta testers. Sorry guys, I need a bit more time...
I anticipated that I would be 'done' after implementing the new login method, but I was wrong - totally wrong.
At first start-up of the new Plugin the firmware version wasn't detected, Country & Area codes, nothing worked anymore!
All due to changes that AVM made in the responses from the Fritz! Box; almost all regular expressions failed to find a match, so I had to study the responses and alter the regular expressions so that they worked again. What a bummer...
The current state (regarding firmwares > xx.05.50) is that the Plugin can login and detect all the values it needs to work:
But I still have to check all other things like the Phonebook, Voicemail, WLAN & TAM buttons because too much has changed to assume that it's still working.
For now, I'm calling it a day - time for some other fun stuff without HS2, Fiddler and watching webpage sources all the time... :wink:
Keep you posted...
strake1
Re: Updating Plugin for newer firmwares
Post by strake1 »
Keep on going! There are many users adicted to this plug-in. Previous versions works great and stable. Good luck!
Sent from my iPhone using Tapatalk
RdP
Post by RdP »
Cool and count me in as a potential beta tester....
blb
Post by blb »
I'm also willing to test Digit
Bernard
Thanks, I'll keep it in mind.
I've already got 2 beta testers on my payroll but if needed I will contact you 2!
BTW, retrieving the Phonebook from the Fritz! Box doesn't seem to be altered :D
RdP
Post by RdP »
What's the current status of the beta ?
Thx,
This weekend 1st beta release.
Digit wrote:This weekend 1st beta release.
Welk weekend bedoel je? :mrgreen:
blb
Post by blb »
Digit did receive his new Cubietruck just before last weekend, so I believe we need to have some patience ;-)
Bernard
Right! :wink: The cubietruck arrived on 26th btw
And I've had the flu for 4 days... :(
And some private issues that need attention.
So I'm a bit behind schedule. Work that still needs to be done: Phonebook retrieval and the buttons for WLAN & Voicemail.
The rest is already working.
RdP
Post by RdP »
Hoi,
Even benieuwd naar de status :D
Groet,
Ik heb deze week zitten klooien met het Phonebook. Op een gegeven moment dacht ik dat ik klaar was, zette bij een test-entry er nog even een business nummer bij en bingo, wat een ellende weer.
De manier waarop dat business nummer is terug te vinden in de data die ik verwerk is echter zo f***d-up dat ik daar niet snel wat mee kon en het zo 'slecht' vond dat ik op zoek ben gegaan naar een alternatieve werkwijze.
Die heb ik inmiddels gevonden, maar ik moet nog testen of dat werkt en zo ja, dan daar weer nieuwe code voor schrijven die dat weer netjes kan verwerken.
Het zit dus niet mee.
blb
Post by blb »
Ik hoop dat je deze dagen de verleiding kan weerstaan e.e.a. met vuurwerk 'op te lossen' :D
Bernard
RdP
Post by RdP »
Durf het bijna niet te vragen, maar is er al licht aan het einde van de tunnel te zien?
De omstandigheden zijn onlangs verbeterd, het gaat nou echt niet lang meer duren.
Echter afgelopen tijd ook druk geweest met m'n day job, de 1e weken van een nieuw jaar zijn altijd druk...
Locked
