Hue config (forced)
Forum about Toon related manuals and tutorials. Read-only for most members.
Hue config (forced)
Postby TerrorSource » Sun Feb 24, 2019 4:40 pm
As a few new members of this forum couldn't find the information about Hue, here is a seperare topic with a few versions.
You can force the Hue-bridge in a settings file when you're bridge (or HA-bridge) isn't found.
Remember. ALWAYS backup your current file!
Folder: /HCBv2/config or /mnt/data/qmf/config
File: config_hdrv_hue.xml
There are different versions of this file. Check your current file which config you need.
REPLACE:
abcdefgh1234 = mac address of your Hue Bridge or HA-bridge device
192.168.x.x = ip address of your Hue Bridge or HA-bridge device
Config packageRevision="167"
<Config packageRevision="167">
  <sysConfig>
   <locale>nl_NL</locale>
   <timezone>Europe/Amsterdam</timezone>
   <currency>EUR</currency></sysConfig>
    <hue_bridge>
     <package>hdrv_hue</package>
     <uuid>daa9c3e9-549d-4c7f-a9a9-fda64b17d0e6</uuid>
     <type>hue_bridge</type>
     <name>Philips hue (192.168.x.x)</name>
     <internalAddress>abcdefgh1234</internalAddress>
     <visibility>1</visibility>
     <profile>ConnectedState</profile><ipAddr>192.168.x.x</ipAddr><modelName>Philips hue bridge 2015</modelName><serialNumber>abcdefgh1234</serialNumber><cfgName>Philips hue</cfgName><swversion>1705121051</swversion><apiVersion>1.19.0</apiVersion><port>80</port><modelNumber>0</modelNumber><linkState>3</linkState></hue_bridge>
  </Config>
Config packageRevision="332"
<Config packageRevision="332">
  <sysConfig>
    <device>
     <refactoredSteps>
    <refactoredStep>refactorNonDeviceClass</refactoredStep></refactoredSteps>
     <uuid>390b0153-f02b-436a-ab50-9f9a46b427de</uuid>
     <type>settingsDev</type>
     <name>settingsDev</name>
     <internalAddress>settingsDev</internalAddress>
     <visibility>1</visibility></device>
    <device>
     <uuid>39ae8b5e-92d4-4548-a7f4-15a49b941ad5</uuid>
     <name>Philips hue</name>
     <profile>ConnectedState</profile><ipAddr>192.168.x.x</ipAddr><modelName>Philips hue bridge</modelName><serialNumber>abcdefgh1234</serialNumber><genUser>b5d78409ae624ae1992d7aa55609b717</genUser><cfgName>HA-Bridge</cfgName>    <swversion>1901181309</swversion><apiVersion>1.29.0</apiVersion><port>80</port><modelNumber>1</modelNumber><linkState>2</linkState></device>
   </device></Config>
TerrorSource
Re: Hue config (forced)
Postby mbnn » Thu Mar 14, 2019 5:27 pm
Hi, thanks for the info, however I have a Hue bridge v2 in my house but the Toon (rooted) does not find the bridge anywhere (it does have a static IP).
I tried changing the file you mention with the right IP and Mac adress in there, but still.. nothing, any idea?
The Hue bridge is working fine with Homey and Homekit.
mbnn
Postby mAiden » Tue Apr 02, 2019 11:21 am
mbnn wrote:Hi, thanks for the info, however I have a Hue bridge v2 in my house but the Toon (rooted) does not find the bridge anywhere (it does have a static IP).
Wich Config packageRevision have you? You can find this in :
mAiden
Postby TerrorSource » Tue Apr 02, 2019 11:44 am
Please check your file as mAiden said.
If you have a different version, please post the file here so i can prepare it and add it to the OP.
TerrorSource
Postby RBI88 » Sun Jul 14, 2019 7:52 pm
Hi i have another revision;
<Config packageRevision="374">
  <sysConfig>
    <device>
     <refactoredSteps>
     <uuid>72cb4fe3-3492-4b4a-befe-c9d570a3c641</uuid>
     <visibility>1</visibility></device></Config>
Could someone update the values that needs to be configured? I can't add my Hue Bridge
RBI88
Postby mAiden » Tue Jan 14, 2020 4:35 pm
RBI88 wrote:Hi i have another revision;
  <sysConfig>
    <device>
     <refactoredSteps>
Check if your HUE bride can be found at: http://www.meethue.com/api/nupnp
Toon will check meethue, if your Hue Bridge is unknown there, Toon will never find it!
mAiden
Return to Manuals/tutorials
