Toon 1 and Toon 2 software rooting
Re: Toon 1 and Toon 2 software rooting
Postby TheHogNL » Thu Oct 07, 2021 9:41 am
Where did you download the rooting script? You are using older versions. This is the place where you need to download:https://github.com/ToonSoftwareCollective/Root-A-Toon
Also, http://qutility.nl/dropbear_2015.71-r0_qb2.ipk should still work but not for you. Are you blocking internet access from the toon to the internet?
Postby Merc » Thu Oct 07, 2021 11:20 am
Hi TheHogNl,
I was using this script
https://github.com/IgorYbema/Root-A-Toon
so far.
Now I have downloaded your latest one.
I am running this on a PI to which I connect the Toon via WIFI, with access to the internet.
So now I reset the Toon and I am waiting for it to ask me to activate it again. It did do this before and I used the activation script but right now it is just sitting there, connected to the network and with the little box saying:
"activieren by service center".
What can I do now to get it to the activation screen again?
Once this is done I will try to run your updated script.
Thanks,
Merc
Merc
Postby TheHogNL » Thu Oct 07, 2021 11:44 am
Merc wrote:Hi TheHogNl,
so far.
Thanks,
Merc
Once activated it should not come back with another activation request. Weird. But because your root attempt failed but did do a part of the rooting, this will not work anymore I am afraid.
You will need the older method with opening the Toon1, connecting cables from the Pi to the toon and using the ToonRooter script
Postby Merc » Thu Oct 07, 2021 11:47 am
I was expecting you to say this.
So which is the latest rooting script for the traditional way then? Dont want to use the wrong one again.
Thanks for your help.
Merc
Postby TheHogNL » Thu Oct 07, 2021 11:51 am
Merc wrote:I was expecting you to say this.
https://github.com/ToonSoftwareCollective/ToonRooter
but a Toon1 can always be recovered whatever you do wrong (on software) :) https://github.com/ToonSoftwareCollective/ToonRecovery
Can you tell me where you found the old github link? I already removed the repository there but want to remove the old link in documentations also
Postby Merc » Fri Oct 08, 2021 7:59 pm
Hi there,
so right at the moment the hardware rooting is running. I am in the process of updating the software to the latest version.
In the console I can see a lot of "y" flashing and on the Toon's screen it says updating software but I am not sure if the progress bar is still moving
Is this the way it should be? Seems to take quite a while and all the informative text messages have disappeared.
Thanks for this script.
Merc
Merc
Postby Merc » Fri Oct 08, 2021 8:23 pm
Hi TheHogNL,
I tried to find where I had picked up this "old" link to Github but cannot recall anymore.
I had bookmarked the page after I had found it.
It was a forum of some kind. If I will find it again I will let you know.
Thanks,
Merc
the toon is still updating the software and the shell is printing a lot of y's
Merc
Postby TheHogNL » Sat Oct 09, 2021 9:18 pm
Merc wrote:Hi TheHogNL,
Should not take that long. If it is still running break it and try again. Hopefully it will pick up. If not, your last thing you can try is the ToonRecovery :(
Postby AntonieB » Thu Oct 21, 2021 10:00 pm
Hello, I'am pretty new to this forum so I don't know exactly what is the normal procedure for asking a question around Toon2 software rooting but this thread seems the right spot.
Thanks in advance for helping me out!
So the problem. I did go the software rooting way following the 'quick guide' at https://www.domoticaforum.eu/viewtopic. ... 235#p82533
So far I can login on my I think rooted Toon 2 but I can't get the 'toonstore' to show up.
When I run: sh update-rooted.sh -f I think I see a problem but don't know if there is a solution. The log is as followws:
Only fixing files.
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.49.7.
[ERROR] Could not download a resources.rcc file for this version! Continuing, but your custom apps probably dont work anymore
EDITING: Disable add google DNS on top of resolv.conf
EDITING: add disable power management wifi on Toon2
EDITING: add autobrightness feature on Toon2
EDITING: disabling Eneco subscription feature apps which are not working on rooted toons
EDITING: disabling KPI and weather happ as these are not necessary on rooted toons
EDITING: download certificate store pem file
EDITING: lighttpd so tsc/sensors is viewable via a browser
Finished fixing files!
I think the problem is there is no TSC mod for my version 5.49.7
I tried searching the forum but can't really find an answer / somebody else having the same problem. I read some things about 'downgrading toon' but I'm not exactly sure if thats the right way?
I hope anybody understands something and can help me out. I do have some experience with linux / raspberry pi / networking etc so only some highlevel tips and tricks could help.
Again thanks already for taking the time to help me out.
AntonieB
Postby TheHogNL » Fri Oct 22, 2021 8:31 am
AntonieB wrote:Hello, I'am pretty new to this forum so I don't know exactly what is the normal procedure for asking a question around Toon2 software rooting but this thread seems the right spot.
This version was not yet available for rooted toons indeed. I just checked and it seems that 5.49.7 is only available for a few official toons right now. But I just created the resource file for it so please try again, should work now.
Postby AntonieB » Fri Oct 22, 2021 1:16 pm
TheHogNL wrote: This version was not yet available for rooted toons indeed. I just checked and it seems that 5.49.7 is only available for a few official toons right now. But I just created the resource file for it so please try again, should work now.
Thats a fast reply! Thank you!
I just tried it and it is working now for me!
Can I buy you a beer somewhere? or any other way to help out?
AntonieB
Postby bafplus » Sat Jan 08, 2022 6:03 pm
Hy al! I am the proud owner of a rooted Toon2, thanks for all the hard work!
However...I friend of mine has a Toon 1 with firmware 5.24.100.
According to the docs you can only root such with a serial device (wich i don't have).
So what are my options to root a Toon1 without a serial cable?
bafplus
Postby TheHogNL » Sun Jan 09, 2022 8:09 pm
bafplus wrote:Hy al! I am the proud owner of a rooted Toon2, thanks for all the hard work!
These versions are talking directly to a online server instead of over vpn. And we need the vpn communication to get the software rooting to work.
You might be lucky if you disable any internet on this toon for a while. At least a week. And then try the software rooting trick. That should invalidate the stored access key to the online server and then it needs vpn again to try to update that.
Previous
Return to Toon Rooting
