You can have it rooted by me for only 10 euros
wallie wrote:I have rooted twices the toon1 succesfully with jtag CP2102 usb with toon older bootloader.
I want to try rooting Toon1 with uboot R10 with Cp2102 Jtag openocd method.
Tried many things downloaded openocd but still unsucesfully.
Can someone help guide me to get connection cp2102 jtag openocd with toon?
i use Windows 10.
i dont know if this is the right place for my question, this is a very usefull forum.
vep9tb wrote:@ TheHogNL:
Are you still available for the rooting of Toon 1, i just had a new Toon 2 installed yesterday which means that i have a complete Toon 1 left over and i want to play with it a bit.
But in order to start playing it needs to be rooted and i do not have the hardware or time to do this myself.
You're link on MP has expired, but if you are still in to it i would like to get in contact, or els maybe someone else who can do this for me?
GreeTz, Patrick.
Daniel wrote:I just rooted a toon1, after root i use sh /root/update-rooted.sh -f normally this works fine and the toon is activated
The toon boot but the last 2mm in the status bar is not running, after 3-4 min the toon starts, but getting te message ist not activated.
when i check /HCBv2/config/config_happ_scsync.xml its indeed not activated.
I have set it a few times to <activated>1</activated> but it is set to 0 after reboot.
The firmware is 5.35.100 maybe thats te isseu, (toon`s slimme functies zijn niet actief)
Daniel wrote:I tried the fix again ,unfortunately it remains to 0
The first time I saw that gas and electricity were also at 0, i set them to 1 and after teboot the where visible in the menu.
TheHogNL wrote:Daniel wrote:I tried the fix again ,unfortunately it remains to 0
Did you already try a factory reset? Or is the current data in the toon important to you?
And before that, do you have a file /qmf/var/hcb_bxtproxy-oidcIdToken.json ? Try to delete and reboot (and fix again).
Daniel wrote:TheHogNL wrote:Daniel wrote:I tried the fix again ,unfortunately it remains to 0
thanks that`s it. delete the file and do the fix. now its working fine!
Rkzr wrote:Hi guys,
I'm trying to root the Toon of my neighbour.
This is a Toon with sn 16, so I've installed openOCD on my RPI4 and using a JTAG cable with the pinout mentioned in the TooonRooter readme.
Everything works fine until the last step:
"Now the Toon loads the “hacked” u-boot loader which has the password “toon”."
I'm able to access the Toon on Serial0 with screen but it look very fuzzy and the password is not accepted and also the session is constantly terminating.
I've tried to connect with putty but this isn't working (error: unable to open serial port).
Does anyone has an idea? Thnx!
