Fully automated rooting script
Re: Fully automated rooting script
Postby Floats » Mon Feb 17, 2020 8:02 pm
mAiden wrote:
Floats wrote:Having an issue with rooting my Toon
When I try to install openOCD :
pi@raspberrypi:~ $ bash
pi@raspberrypi:~ $ git clone --recursive git://git.code.sf.net/p/openocd/code openocd
Cloning into 'openocd'...
remote: Enumerating objects: 62985, done.
remote: Counting objects: 100% (62985/62985), done.
remote: Compressing objects: 100% (26823/26823), done.
remote: Total 62985 (delta 51779), reused 43800 (delta 35996)
Receiving objects: 100% (62985/62985), 14.22 MiB | 4.93 MiB/s, done.
Resolving deltas: 100% (51779/51779), done.
Submodule 'jimtcl' (https://repo.or.cz/jimtcl.git) registered for path 'jimtcl'
Submodule 'src/jtag/drivers/libjaylink' (https://repo.or.cz/libjaylink.git) registered for path 'src/jtag/drivers/libjaylink'
Submodule 'tools/git2cl' (https://repo.or.cz/git2cl.git) registered for path 'tools/git2cl'
Cloning into '/home/pi/openocd/jimtcl'...
remote: Counting objects: 7715, done.
remote: Total 7715 (delta 0), reused 0 (delta 0)        /s
Receiving objects: 100% (7715/7715), 6.05 MiB | 4.17 MiB/s, done.
Resolving deltas: 100% (5609/5609), done.
Cloning into '/home/pi/openocd/tools/git2cl'...
remote: Counting objects: 64, done.
remote: Total 64 (delta 0), reused 0 (delta 0)
Cloning into '/home/pi/openocd/src/jtag/drivers/libjaylink'...
remote: Counting objects: 1004, done.
remote: Total 1004 (delta 0), reused 0 (delta 0)
Receiving objects: 100% (1004/1004), 236.74 KiB | 1.94 MiB/s, done.
Resolving deltas: 100% (767/767), done.
Submodule path 'jimtcl': checked out 'a9bf5975fd0f89974d689a2d9ebd0873c8d64787'
Submodule path 'src/jtag/drivers/libjaylink': checked out 'f73ad5e667ae8b26a52b847c603fdadaabf302a6'
Submodule path 'tools/git2cl': checked out '8373c9f74993e218a08819cbcdbab3f3564bbeba'
pi@raspberrypi:~ $ cd openocd
pi@raspberrypi:~/openocd $ sudo apt install make libtool libtool-bin pkg-config autoconf automake texinfo libusb-1.0 libusb-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'libusb-1.0-0' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-0-dev' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-doc' for regex 'libusb-1.0'
libusb-1.0-0 is already the newest version (2:1.0.22-2).
libusb-1.0-0 set to manually installed.
make is already the newest version (4.2.1-1.2).
make set to manually installed.
pkg-config is already the newest version (0.29-6).
The following additional packages will be installed:
  autotools-dev libauthen-sasl-perl libdata-dump-perl libencode-locale-perl
  libfile-listing-perl libfont-afm-perl libhtml-form-perl libhtml-format-perl
  libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl
  libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl
  libhttp-message-perl libhttp-negotiate-perl libio-html-perl
  libio-socket-ssl-perl libltdl-dev liblwp-mediatypes-perl
  liblwp-protocol-https-perl libmailtools-perl libnet-http-perl
  libnet-smtp-ssl-perl libnet-ssleay-perl libsigsegv2 libtext-unidecode-perl
  libtimedate-perl libtry-tiny-perl liburi-perl libwww-perl
  libwww-robotrules-perl libxml-libxml-perl libxml-namespacesupport-perl
  libxml-parser-perl libxml-sax-base-perl libxml-sax-expat-perl
  libxml-sax-perl m4 perl-openssl-defaults tex-common
Suggested packages:
  autoconf-archive gnu-standards autoconf-doc gettext libdigest-hmac-perl
  libgssapi-perl libtool-doc libcrypt-ssleay-perl gfortran
  | fortran95-compiler gcj-jdk libauthen-ntlm-perl libxml-sax-expatxs-perl
  m4-doc debhelper texlive-base texlive-latex-base texlive-generic-recommended
  texinfo-doc-nonfree texlive-fonts-recommended
The following NEW packages will be installed:
  autoconf automake autotools-dev libauthen-sasl-perl libdata-dump-perl
  libencode-locale-perl libfile-listing-perl libfont-afm-perl
  libhtml-form-perl libhtml-format-perl libhtml-parser-perl
  libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl
  libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
  libhttp-negotiate-perl libio-html-perl libio-socket-ssl-perl libltdl-dev
  liblwp-mediatypes-perl liblwp-protocol-https-perl libmailtools-perl
  libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl libsigsegv2
  libtext-unidecode-perl libtimedate-perl libtool libtool-bin libtry-tiny-perl
  liburi-perl libusb-1.0-0-dev libusb-1.0-doc libusb-dev libwww-perl
  libxml-sax-perl m4 perl-openssl-defaults tex-common texinfo
0 upgraded, 49 newly installed, 0 to remove and 0 not upgraded.
Need to get 6,711 kB of archives.
After this operation, 25.9 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Abort.
And then when I try to Root the toon :
pi@raspberrypi:~ $ sudo apt install python-serial python-cryptography
python-cryptography is already the newest version (2.6.1-3+deb10u2).
python-cryptography set to manually installed.
python-serial is already the newest version (3.4-4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi:~ $ git clone https://github.com/martenjacobs/ToonRooter.git
Cloning into 'ToonRooter'...
remote: Enumerating objects: 19, done.
remote: Counting objects: 100% (19/19), done.
remote: Compressing objects: 100% (19/19), done.
remote: Total 200 (delta 7), reused 3 (delta 0), pack-reused 181
Receiving objects: 100% (200/200), 439.99 KiB | 1.30 MiB/s, done.
Resolving deltas: 100% (96/96), done.
pi@raspberrypi:~ $ cd ToonRooter
pi@raspberrypi:~/ToonRooter $ sudo python . --jtag-available
INFO:__main__:Starting up...
INFO:__main__:Detected JTAG hardware 'rpi3'
INFO:__main__:Written private and public key pair to ./id_rsa and ./id_rsa.pub, respectively
INFO:rooter:Toon has U-Boot version 2010.09-R10
INFO:rooter:Loading new bootloader
INFO:rooter:Starting openocd
CRITICAL:__main__:[Errno 2] No such file or directory
pi@raspberrypi:~/ToonRooter $ --output-level DEBUG
bash: --output-level: command not found
I'm using a raspberry Pi 3 B+ with fresh installed Raspbian.
You did the install of OpenOCD wrong, look at this:
cd openocd
./bootstrap &&\
./configure --enable-sysfsgpio\
     --enable-bcm2835gpio \
     --prefix=/usr\
make -j4
} 2>&1 | tee openocd_build.log
sudo make install
Go to OpenOCD:
cd openocd
Then run the following command (Use everything what here stand!):
./bootstrap &&\
     --prefix=/usr\
make -j4
And the run this command:
sudo make install
Thanks for the response!
I've tried it your way but still without succes..
This is what I'm getting :
Suggested packages:
Do you want to continue? [Y/n] sudo make install
Abort.
Floats
Postby TheHogNL » Tue Feb 18, 2020 8:55 am
Just don't simply copy paste .. read and try to understand what you are doing.
Postby hmay » Sun May 03, 2020 9:54 am
I am trying to root a Toon with U-Boot version 2010.09-R10 but I am running into problems with OpenOCD.
I started with a clean install of stretch on a pi 3b, disabled the serial login shell and enabled the serial interface.
I also did a sudo apt-get update / upgrade.
I followed te readme of martenjacobs on GitHub exactly as writen including the OpenOCD install.
Then connected the Toon and ran the rooting script with the following output:
pi@raspberrypi:~/ToonRooter$ sudo python . --jtag-available --output-level DEBUG
DEBUG:__main__:{"uboot_only": false, "has_jtag": true, "check_uboot": true, "boot_only": false, "reboot_after": true, "cleanup_payload": true, "port": "/dev/serial0", "jtag_hardware": "rpi3", "ssh_pubkey_data": "ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDZnL1FMePQyxXTuIT9n868t6Mu04eO2o+JpgoLSlrY77cIGQiK+KqVsEvwJ5gFE8Xnnvk9KKAv1O4pUY06erwRJoqcLkPe7ioVth9HaJRmrRgJm4NUwjxZll/CaT5hUZb6RlGBKKqt+H2p05jNchuydV7KXtzLanRsUtDnLrppRsRcbOyYrXj+Xwklni7tqIbWMxxeG/i3SXdU9JhUmb5k54ZtA+5MXDyx0zQskCK2W6frgYMAkPtG/MFFl5isDMfyVjbT9OQm3vcGHEvr6LEmfKK63/baRCmVzHSTVZnJm790Lr4IcB5F1RopOkqC9Rc0D4ks3H+oZQ/zAcsfSPqH"}
INFO:rooter:Waiting for 10 seconds
ERROR:rooter:
  File "./rooter.py", line 211, in start_bootloader
    client = telnetlib.Telnet('localhost', 4444)
  File "/usr/lib/python2.7/telnetlib.py", line 211, in __init__
    self.open(host, port, timeout)
  File "/usr/lib/python2.7/telnetlib.py", line 227, in open
    self.sock = socket.create_connection((host, port), timeout)
  File "/usr/lib/python2.7/socket.py", line 575, in create_connection
    raise err
error: [Errno 111] Connection refused
  File "/usr/lib/python2.7/runpy.py", line 174, in _run_module_as_main
    "__main__", fname, loader, pkg_name)
  File "/usr/lib/python2.7/runpy.py", line 72, in _run_code
    exec code in run_globals
  File "/home/pi/ToonRooter/__main__.py", line 187, in <module>
    main()
  File "/home/pi/ToonRooter/__main__.py", line 183, in main
    rooter.Rooter(**params).run()
  File "./rooter.py", line 76, in run
    self.start_bootloader("assets/u-boot.bin")
  File "./rooter.py", line 231, in start_bootloader
    proc.terminate()
  File "/usr/lib/python2.7/subprocess.py", line 1248, in terminate
    self.send_signal(signal.SIGTERM)
  File "/usr/lib/python2.7/subprocess.py", line 1243, in send_signal
    os.kill(self.pid, sig)
I saw a similar issue in the thread which was solved by installing OpenOCD again.
I did another clean install but the issue remains the same.
If a start OpenOCD the I am getting the following output:
pi@raspberrypi:~/openocd$ openocd
Open On-Chip Debugger 0.10.0+dev-01209-g8f2afaaf-dirty (2020-05-03-10:05)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.org/doc/doxygen/bugs.html
embedded:startup.tcl:26: Error: Can't find openocd.cfg
in procedure 'script'
at file "embedded:startup.tcl", line 26
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Error: Debug Adapter has to be specified, see "adapter driver" command
I am lost, what goes wrong?
Your help is much appreciated!
hmay
Postby TheHogNL » Sun May 03, 2020 12:57 pm
hmay wrote:I am lost, what goes wrong?
Your output suggest openocd isn't working but your test failed because you didn't start openocd with the command needed, try: sudo openocd -s /usr/share/openocd -f assets/adapters/rpi3.cfg -f assets/boards/ed20.cfg (from the ToonRooter directory)
Postby hmay » Sun May 03, 2020 1:09 pm
Thanks for the quick reply.
It appears that OpenOCD is missing an interface: bcm2835gpio.
However I did enter the
line.
Could it be related to the order in which I have installed the tools?
I started with ToonRooter and after that I installed the OpenOCD stuff.
pi@raspberrypi:~/ToonRooter$  sudo openocd -s /usr/share/openocd -f assets/adapters/rpi3.cfg -f assets/boards/ed20.cfg
DEPRECATED! use 'adapter driver' not 'interface'
Error: The specified debug interface was not found (bcm2835gpio)
The following debug adapters are available:
1: ftdi
2: usb_blaster
3: ft232r
4: usbprog
5: jlink
6: vsllink
7: rlink
8: ulink
9: arm-jtag-ew
10: hla
11: osbdm
12: opendous
13: aice
14: xds110
15: st-link
hmay
Postby TheHogNL » Sun May 03, 2020 3:09 pm
hmay wrote:It appears that OpenOCD is missing an interface: bcm2835gpio.
line.
No that is not a problem.
Try recompiling openocd and try to figure out with the bcm2835gpio isn't added.
Postby hmay » Mon May 04, 2020 11:31 am
I finally got the OpenOCD software correctly installed.
I could not get it to work if I follow the instructions from the readme of martenjacobs on GitHub.
Instead I used the following commands for the install:
cd openocd
./bootstrap
./configure --enable-sysfsgpio --enable-bcm2835gpio --prefix=/usr
make -j4
sudo make install
The rooting script worked great and my Toon is set free!
Thanks for pointing me into the right direction.
By the way, the rooting script is a piece of art :D
hmay
Postby TheHogNL » Mon May 04, 2020 12:12 pm
That is the same commands (only without the subfunction around it).
I'll update the README on the toonrooter TSC github page because I see often people not copy pasting this correctly :)
Postby EricvL » Wed May 06, 2020 3:11 pm
Hi guys,
I recently decided to root my Toon and I ordered a FTDI breakout like this:
Originally I was planning to use the very well documented instructions from Dennis Bors website (https://www.dennisbor.com/2020/01/19/toon-rooten/), but I like the idea of using the ToonRooter script. I only find it very hard to find/understand the instructions when not using a PI. For instance, there are a lot of parameters to specify, but I don't know which are mandatory and which aren't.
I'm planning to boot my laptop and use a KALI distribution. Does that matter or will most Linux distros work?
Thanks for any help in advance!
Kind regards,
Eric
EricvL
Postby TheHogNL » Wed May 06, 2020 9:16 pm
EricvL wrote:Hi guys,
Kind regards,
Eric
ToonRooter is a simple python script so install (if not already installed in kali) python and the necessary libraries (https://github.com/ToonSoftwareCollecti ... pendencies) and then run the python script (as mentioned in toonrooter readme). Nothing special here (nothing to do with a Pi).
Only thing is, if you happen to have a Toon with uboot R10 you need jtag connection and openocd installed (which the toonrooter will use then). And from that point, it is easier to use a Pi because it has jtag headers on it.
And about DennisBor site.. it is just a copy of the documentation which is on this forum for about 6 years now.
And it is old. It is wrong about a few parts (like, I don't recommend installing getty and busybox. And it is missing about providing a configured encrypted password).
Als DennisBor is mentioning (after update-rooted.sh -f ) to change some configs. But that is already done using the update script so that is unnecessary.
Postby EricvL » Thu May 07, 2020 8:32 am
Thank you very much again for your help, I appreciate it! I will give it a try and let you know the results.
EricvL
Postby rickvnl » Tue May 26, 2020 12:50 pm
About two years ago I rooted my Toon 1 with this great script.
Since then I didn't update or so. Now I want to update but I can't remember my SSH login.
Are there default passwords?
Or can I reset the password?
Running sw version 4.19.10 now. So no option in the Toon to show the password.
rickvnl
Postby TerrorSource » Tue May 26, 2020 1:28 pm
rickvnl wrote:About two years ago I rooted my Toon 1 with this great script.
Depends on the way you rooted the toon at that time.
If you used ToonRooter it generated a random password while rooting.
If you did it by hand you can try "toon" as password.
If you dont remember the password, try re-rooting it with ToonRooter.
TerrorSource
Postby Jasper » Fri Jun 12, 2020 6:28 pm
Tried this, It looks like it worked and then I have no idea how to continue.
I can SSH into the Toon using the password on the screen from the pi.
The Toon says no connection with Eneco server which should be okay I think.
What's the next step I missed?
Jasper
Postby TerrorSource » Fri Jun 12, 2020 6:56 pm
Jasper wrote:Tried this, It looks like it worked and then I have no idea how to continue.
Well, you can download the update-rooted.sh script, update the Toon and run the fixes. Or just run the fixes. That should be enough.
TerrorSource
PreviousNext
Return to Toon Rooting
