Toon and rpi hardware requirements
Postby jumans » Mon Nov 18, 2019 10:52 pm
Hi all where can I but the connector for the pi to the toon and do I need any more hardware,
Can you paste and link
Cheers
Jumans
jumans
Re: Toon and rpi hardware requirements
Postby TheHogNL » Tue Nov 19, 2019 8:02 am
Everything you need is in de roonrooter readme (https://github.com/ToonSoftwareCollective/ToonRooter)
Wires from the pi to the toon are called 'jumper wires' and in this case female to female. And that's all you need (except for a Pi and a Toon ofcourse).
Postby jumans » Tue Nov 19, 2019 11:01 am
awesome thanks
jumans
Postby jumans » Thu Nov 21, 2019 12:44 am
I've managed to root the toon. How can i get the toonstore installed,
I cannot seem to add it and the interface is the same before, it only shows the 8 basic apps.
I have software version 5.5.7
jumans
Postby TheHogNL » Thu Nov 21, 2019 1:32 pm
jumans wrote:I've managed to root the toon. How can i get the toonstore installed,
You need to read the how to root guide: https://www.domoticaforum.eu/viewtopic. ... 235#p82533
Probably you forgot to use the update-rooted.sh script with option -f to finalize the rooting process.
Postby TerrorSource » Fri Nov 22, 2019 6:57 pm
you can run the update-rooted.sh script with -f option or you can run the script, update to 5.15.6 and execute the fixes at the end.
TerrorSource
Return to Toon Rooting
