Hi Many thanks for your reply
i removed the early installed openocd directory
pi@raspberrypi:~ $ rm -Rf openocd
pi@raspberrypi:~ $ git clone --recursive git://git.code.sf.net/p/openocd/code openocd
Cloning into 'openocd'...
remote: Enumerating objects: 62129, done.
remote: Counting objects: 100% (62129/62129), done.
remote: Compressing objects: 100% (26074/26074), done.
remote: Total 62129 (delta 51041), reused 43563 (delta 35892)
Receiving objects: 100% (62129/62129), 14.07 MiB | 3.01 MiB/s, done.
Resolving deltas: 100% (51041/51041), done.
Checking out files: 100% (1668/1668), done.
Submodule 'jimtcl' (
http://repo.or.cz/r/jimtcl.git) registered for path 'jimtcl'
Submodule 'src/jtag/drivers/libjaylink' (
http://repo.or.cz/r/libjaylink.git) registered for path 'src/jtag/drivers/libjaylink'
Submodule 'tools/git2cl' (
http://repo.or.cz/r/git2cl.git) registered for path 'tools/git2cl'
Cloning into '/home/pi/openocd/jimtcl'...
warning: redirecting to
https://repo.or.cz/r/jimtcl.git/
remote: Counting objects: 7712, done.
remote: Total 7712 (delta 0), reused 0 (delta 0) /s
Receiving objects: 100% (7712/7712), 6.05 MiB | 2.00 MiB/s, done.
Resolving deltas: 100% (5607/5607), done.
Cloning into '/home/pi/openocd/tools/git2cl'...
https://repo.or.cz/r/git2cl.git/
remote: Counting objects: 64, done.
remote: Total 64 (delta 0), reused 0 (delta 0)
Cloning into '/home/pi/openocd/src/jtag/drivers/libjaylink'...
https://repo.or.cz/r/libjaylink.git/
remote: Counting objects: 1004, done.
remote: Total 1004 (delta 0), reused 0 (delta 0)
Receiving objects: 100% (1004/1004), 236.74 KiB | 881.00 KiB/s, done.
Resolving deltas: 100% (767/767), done.
Submodule path 'jimtcl': checked out 'a9bf5975fd0f89974d689a2d9ebd0873c8d64787'
Submodule path 'src/jtag/drivers/libjaylink': checked out 'f73ad5e667ae8b26a52b847c603fdadaabf302a6'
Submodule path 'tools/git2cl': checked out '8373c9f74993e218a08819cbcdbab3f3564bbeba'
then copy & paste the following code: (with PuTTY over ethernet)
cd openocd
sudo apt install make libtool libtool-bin pkg-config autoconf automake texinfo libusb-1.0 libusb-dev
./bootstrap &&\
./configure --enable-sysfsgpio\
--enable-bcm2835gpio \
--prefix=/usr\
make -j4
} 2>&1 | tee openocd_build.log
sudo make install
a large log file is produced too long to fully capture but the end looks like this:
rm_disassembler.o src/.libs/libopenocd.lax/libtarget.a/arm_dpm.o src/.libs/libop enocd.lax/libtarget.a/arm_jtag.o src/.libs/libopenocd.lax/libtarget.a/arm_semiho sting.o src/.libs/libopenocd.lax/libtarget.a/arm_simulator.o src/.libs/libopenoc d.lax/libtarget.a/armv4_5.o src/.libs/libopenocd.lax/libtarget.a/armv4_5_cache.o src/.libs/libopenocd.lax/libtarget.a/armv4_5_mmu.o src/.libs/libopenocd.lax/lib target.a/armv7a.o src/.libs/libopenocd.lax/libtarget.a/armv7a_cache.o src/.libs/ libopenocd.lax/libtarget.a/armv7a_cache_l2x.o src/.libs/libopenocd.lax/libtarget .a/armv7a_mmu.o src/.libs/libopenocd.lax/libtarget.a/armv7m.o src/.libs/libopeno cd.lax/libtarget.a/armv7m_trace.o src/.libs/libopenocd.lax/libtarget.a/armv8.o s rc/.libs/libopenocd.lax/libtarget.a/armv8_cache.o src/.libs/libopenocd.lax/libta rget.a/armv8_dpm.o src/.libs/libopenocd.lax/libtarget.a/armv8_opcodes.o src/.lib s/libopenocd.lax/libtarget.a/avr32_ap7k.o src/.libs/libopenocd.lax/libtarget.a/a vr32_jtag.o src/.libs/libopenocd.lax/libtarget.a/avr32_mem.o src/.libs/libopenoc d.lax/libtarget.a/avr32_regs.o src/.libs/libopenocd.lax/libtarget.a/avrt.o src/. libs/libopenocd.lax/libtarget.a/batch.o src/.libs/libopenocd.lax/libtarget.a/bre akpoints.o src/.libs/libopenocd.lax/libtarget.a/cortex_a.o src/.libs/libopenocd. lax/libtarget.a/cortex_m.o src/.libs/libopenocd.lax/libtarget.a/dsp563xx.o src/. libs/libopenocd.lax/libtarget.a/dsp563xx_once.o src/.libs/libopenocd.lax/libtarg et.a/dsp5680xx.o src/.libs/libopenocd.lax/libtarget.a/embeddedice.o src/.libs/li bopenocd.lax/libtarget.a/esirisc.o src/.libs/libopenocd.lax/libtarget.a/esirisc_ jtag.o src/.libs/libopenocd.lax/libtarget.a/esirisc_trace.o src/.libs/libopenocd .lax/libtarget.a/etb.o src/.libs/libopenocd.lax/libtarget.a/etm.o src/.libs/libo penocd.lax/libtarget.a/etm_dummy.o src/.libs/libopenocd.lax/libtarget.a/fa526.o src/.libs/libopenocd.lax/libtarget.a/feroceon.o src/.libs/libopenocd.lax/libtarg et.a/hla_target.o src/.libs/libopenocd.lax/libtarget.a/image.o src/.libs/libopen ocd.lax/libtarget.a/jsp_server.o src/.libs/libopenocd.lax/libtarget.a/lakemont.o src/.libs/libopenocd.lax/libtarget.a/ls1_sap.o src/.libs/libopenocd.lax/libtarg et.a/lt1-mips32_pracc.o src/.libs/libopenocd.lax/libtarget.a/lt2-trace.o src/.li bs/libopenocd.lax/libtarget.a/lt3-mips_ejtag.o src/.libs/libopenocd.lax/libtarge t.a/mem_ap.o src/.libs/libopenocd.lax/libtarget.a/mips32.o src/.libs/libopenocd. lax/libtarget.a/mips32_dmaacc.o src/.libs/libopenocd.lax/libtarget.a/mips32_prac c.o src/.libs/libopenocd.lax/libtarget.a/mips64.o src/.libs/libopenocd.lax/libta rget.a/mips64_pracc.o src/.libs/libopenocd.lax/libtarget.a/mips_ejtag.o src/.lib s/libopenocd.lax/libtarget.a/mips_m4k.o src/.libs/libopenocd.lax/libtarget.a/mip s_mips64.o src/.libs/libopenocd.lax/libtarget.a/nds32.o src/.libs/libopenocd.lax /libtarget.a/nds32_aice.o src/.libs/libopenocd.lax/libtarget.a/nds32_cmd.o src/. libs/libopenocd.lax/libtarget.a/nds32_disassembler.o src/.libs/libopenocd.lax/li btarget.a/nds32_reg.o src/.libs/libopenocd.lax/libtarget.a/nds32_tlb.o src/.libs /libopenocd.lax/libtarget.a/nds32_v2.o src/.libs/libopenocd.lax/libtarget.a/nds3 2_v3.o src/.libs/libopenocd.lax/libtarget.a/nds32_v3_common.o src/.libs/libopeno cd.lax/libtarget.a/nds32_v3m.o src/.libs/libopenocd.lax/libtarget.a/or1k.o src/. libs/libopenocd.lax/libtarget.a/or1k_du_adv.o src/.libs/libopenocd.lax/libtarget .a/or1k_tap_mohor.o src/.libs/libopenocd.lax/libtarget.a/or1k_tap_vjtag.o src/.l ibs/libopenocd.lax/libtarget.a/or1k_tap_xilinx_bscan.o src/.libs/libopenocd.lax/ libtarget.a/program.o src/.libs/libopenocd.lax/libtarget.a/quark_d20xx.o src/.li bs/libopenocd.lax/libtarget.a/quark_x10xx.o src/.libs/libopenocd.lax/libtarget.a /register.o src/.libs/libopenocd.lax/libtarget.a/riscv-011.o src/.libs/libopenoc d.lax/libtarget.a/riscv-013.o src/.libs/libopenocd.lax/libtarget.a/riscv.o src/. libs/libopenocd.lax/libtarget.a/riscv_semihosting.o src/.libs/libopenocd.lax/lib target.a/semihosting_common.o src/.libs/libopenocd.lax/libtarget.a/smp.o src/.li bs/libopenocd.lax/libtarget.a/stm8.o src/.libs/libopenocd.lax/libtarget.a/target .o src/.libs/libopenocd.lax/libtarget.a/target_request.o src/.libs/libopenocd.la x/libtarget.a/testee.o src/.libs/libopenocd.lax/libtarget.a/trace.o src/.libs/li bopenocd.lax/libtarget.a/x86_32_common.o src/.libs/libopenocd.lax/libtarget.a/xs cale.o src/.libs/libopenocd.lax/libserver.a/libserver_la-gdb_server.o src/.libs/ libopenocd.lax/libserver.a/libserver_la-server.o src/.libs/libopenocd.lax/libser ver.a/libserver_la-server_stubs.o src/.libs/libopenocd.lax/libserver.a/libserver _la-tcl_server.o src/.libs/libopenocd.lax/libserver.a/libserver_la-telnet_server .o src/.libs/libopenocd.lax/librtos.a/librtos_la-ChibiOS.o src/.libs/libopenocd. lax/librtos.a/librtos_la-FreeRTOS.o src/.libs/libopenocd.lax/librtos.a/librtos_l a-ThreadX.o src/.libs/libopenocd.lax/librtos.a/librtos_la-chromium-ec.o src/.lib s/libopenocd.lax/librtos.a/librtos_la-eCos.o src/.libs/libopenocd.lax/librtos.a/ librtos_la-embKernel.o src/.libs/libopenocd.lax/librtos.a/librtos_la-hwthread.o src/.libs/libopenocd.lax/librtos.a/librtos_la-linux.o src/.libs/libopenocd.lax/l ibrtos.a/librtos_la-mqx.o src/.libs/libopenocd.lax/librtos.a/librtos_la-nuttx.o src/.libs/libopenocd.lax/librtos.a/librtos_la-rtos.o src/.libs/libopenocd.lax/li brtos.a/librtos_la-rtos_chibios_stackings.o src/.libs/libopenocd.lax/librtos.a/l ibrtos_la-rtos_ecos_stackings.o src/.libs/libopenocd.lax/librtos.a/librtos_la-rt os_embkernel_stackings.o src/.libs/libopenocd.lax/librtos.a/librtos_la-rtos_mqx_ stackings.o src/.libs/libopenocd.lax/librtos.a/librtos_la-rtos_standard_stacking s.o src/.libs/libopenocd.lax/librtos.a/librtos_la-rtos_ucos_iii_stackings.o src/ .libs/libopenocd.lax/librtos.a/librtos_la-uCOS-III.o src/.libs/libopenocd.lax/li bhelper.a/libhelper_la-binarybuffer.o src/.libs/libopenocd.lax/libhelper.a/libhe lper_la-command.o src/.libs/libopenocd.lax/libhelper.a/libhelper_la-configuratio n.o src/.libs/libopenocd.lax/libhelper.a/libhelper_la-fileio.o src/.libs/libopen ocd.lax/libhelper.a/libhelper_la-ioutil_stubs.o src/.libs/libopenocd.lax/libhelp er.a/libhelper_la-jep106.o src/.libs/libopenocd.lax/libhelper.a/libhelper_la-jim -nvp.o src/.libs/libopenocd.lax/libhelper.a/libhelper_la-log.o src/.libs/libopen ocd.lax/libhelper.a/libhelper_la-options.o src/.libs/libopenocd.lax/libhelper.a/ libhelper_la-replacements.o src/.libs/libopenocd.lax/libhelper.a/libhelper_la-ti me_support.o src/.libs/libopenocd.lax/libhelper.a/libhelper_la-time_support_comm on.o src/.libs/libopenocd.lax/libhelper.a/libhelper_la-util.o
ar: `u' modifier ignored since `D' is the default (see `U')
libtool: link: ranlib src/.libs/libopenocd.a
libtool: link: rm -fr src/.libs/libopenocd.lax src/.libs/libopenocd.lax
libtool: link: ( cd "src/.libs" && rm -f "libopenocd.la" && ln -s "../libopenocd .la" "libopenocd.la" )
/bin/bash ./libtool --tag=CC --mode=link gcc -Wall -Wstrict-prototypes -Wform at-security -Wshadow -Wextra -Wno-unused-parameter -Wbad-function-cast -Wcast-al ign -Wredundant-decls -Werror -g -O2 -o src/openocd src/main.o src/libopenocd. la ./jimtcl/libjim.a -ldl
libtool: link: gcc -Wall -Wstrict-prototypes -Wformat-security -Wshadow -Wextra -Wno-unused-parameter -Wbad-function-cast -Wcast-align -Wredundant-decls -Werror -g -O2 -o src/openocd src/main.o src/.libs/libopenocd.a -lusb -lusb-1.0 -lm ./ jimtcl/libjim.a -ldl
make[2]: Map '/home/pi/openocd' wordt verlaten
make[1]: Map '/home/pi/openocd' wordt verlaten
pi@raspberrypi:~/openocd $
Then i run the script:
pi@raspberrypi:~/ToonRooter $ sudo python . --jtag-available --output-level DEBUG
INFO:__main__:Starting up...
INFO:__main__:Detected JTAG hardware 'rpi2'
INFO:__main__:Written private and public key pair to ./id_rsa and ./id_rsa.pub, respectively
DEBUG:__main__:{"uboot_only": false, "has_jtag": true, "check_uboot": true, "boot_only": false, "reboot_after": true, "cleanup_payload": true, "port": "/dev/serial0", "jtag_hardware": "rpi2", "ssh_pubkey_data": "ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDKu6Wy2F7yKpYbUJfClbAiMjZDyCxkPAl2QNr8xr3ETTpkLfckuU5dKJXV0gEqIy6OunadB9NU4tXcw1IGVkSryoTkEb1Qqw91RUyle6zacnnVKAiVNsfY40cqKfdtxmBaeq1bKhJYXNowV4r63Sb1SMbTKO248lMOBmOR98JUdU/238mhiHGq5fJp3G+zPRP48NV0bogWF5Zbtt4gcbsNfaGSjk+WvakDfGfBfzJLypBlV7akMyOF4Icjjrc6cIIsglvZUnkwSO2KuYYCv6ve51/P+4PbbbNrawxTla1SkFZ0B6c+se1g3/e3NwSkbXJXgZ4pmJYvLBDa926gjVLJ"}
INFO:rooter:Waiting for Toon to restart
INFO:rooter:Toon has U-Boot version 2010.09-R10
INFO:rooter:Loading new bootloader
INFO:rooter:Starting openocd
INFO:rooter:Waiting for 10 seconds
ERROR:rooter:
Traceback (most recent call last):
File "./rooter.py", line 211, in start_bootloader
client = telnetlib.Telnet('localhost', 4444)
File "/usr/lib/python2.7/telnetlib.py", line 211, in __init__
self.open(host, port, timeout)
File "/usr/lib/python2.7/telnetlib.py", line 227, in open
self.sock = socket.create_connection((host, port), timeout)
File "/usr/lib/python2.7/socket.py", line 575, in create_connection
raise err
error: [Errno 111] Connection refused
File "/usr/lib/python2.7/runpy.py", line 174, in _run_module_as_main
"__main__", fname, loader, pkg_name)
File "/usr/lib/python2.7/runpy.py", line 72, in _run_code
exec code in run_globals
File "/home/pi/ToonRooter/__main__.py", line 187, in <module>
main()
File "/home/pi/ToonRooter/__main__.py", line 183, in main
rooter.Rooter(**params).run()
File "./rooter.py", line 76, in run
self.start_bootloader("assets/u-boot.bin")
File "./rooter.py", line 231, in start_bootloader
proc.terminate()
File "/usr/lib/python2.7/subprocess.py", line 1274, in terminate
self.send_signal(signal.SIGTERM)
File "/usr/lib/python2.7/subprocess.py", line 1269, in send_signal
os.kill(self.pid, sig)
OSError: [Errno 3] No such process
Still no luck, what can i do or check?
