rooted Toon Fibaro Hc2
Ruud
Post by Ruud »
Has anyone already linked the rooted Toon to a Fibaro Hc2 via Vd and Lua?
Ruud (rualblas)
fkruis
Re: rooted Toon Fibaro Hc2
Post by fkruis »
HI ruud,
i have build a virtual device for a rooted toon.
send me a Pm en i will sewn dit to you.
If more people are interested i could share in in the forum
Ruud
Post by Ruud »
Pm sent
Ruud (rualblas)
Ruud
Post by Ruud »
Hi Frans,
Its working great :-)
Ruud (rualblas)
Post by TheHogNL »
Please share it in the forum for future use of other hc2 users
TerrorSource
Post by TerrorSource »
@Ruud is is possible that you make a manual for it so other users can also benefit from your findings?
Moved to "external control" forum.
Seems more appropriate.
fkruis
Post by fkruis »
Here is the virtual device as requested,
there are now two virtual devices.
toom connect updated to version 1.25
Toon data version 0.2
toon connect 1.25:
> adjustments on the label naming to provide a beter blok programming experience
> minor bug fixes
> extra functions
toonconnect 1.25.JPG (48.44 KiB) Viewed 13887 times
toon data 0.23:
displays statics data from the toon.
has beta status.
toondata 0,23.JPG (57.07 KiB) Viewed 13887 times
reply's , ideas are welkom.
Toon_Connect_1.25.zip
toon connect version 1.25
(5.83 KiB) Downloaded 616 times
Toon_Data__0.23.zip
toon data version 0.23
(2.39 KiB) Downloaded 593 times
Kenmar
Post by Kenmar »
Hi, is this VD still working?
SDeath
Post by SDeath »
Yes they are still working for me.
Toon1 running firmware 5.33.9 (rooted)
Kenmar
Post by Kenmar »
SDeath wrote:Yes they are still working for me.
Oke thank you for your reply!
RubenNL
Post by RubenNL »
Looks great! Installed it but can't figure out which TCD port my Toon uses. Where can I find this? Thanks in advance!
TerrorSource
RubenNL wrote:Looks great! Installed it but can't figure out which TCD port my Toon uses. Where can I find this? Thanks in advance!
Try port 80 or 10080
SDeath
Post by SDeath »
I got my HC3 to replace my HC2 last week, and been busy converting everything manually, I have lot's of LUA in my HC.
And also converted the VD by fkruis to a HC3 QuickApp.
I have them attached to this post.
Both QuickApps will start updating within 1 minute and keep doing so every minute automatically.
All functions work like before.
Just change the IP address for each QuickApp in the QuickApp Variables to the IP of your Toon and it should work:
Toon_Connect_3.1.fqa.zip
Bug fix for local QuickApp variable change.
(3.02 KiB) Downloaded 351 times
Toon_Data_3.0_VAR.fqa.zip
(2.11 KiB) Downloaded 326 times
SDeath
Post by SDeath »
Updated my previous post to fix a bug.
Please download 3.1 version of the Connect app.
