rooted Toon Fibaro Hc2
Has anyone already linked the rooted Toon to a Fibaro Hc2 via Vd and Lua?
Ruud (rualblas)
Re: rooted Toon Fibaro Hc2
HI ruud,
i have build a virtual device for a rooted toon.
send me a Pm en i will sewn dit to you.
If more people are interested i could share in in the forum
Please share it in the forum for future use of other hc2 users
- Administrator
@Ruud is is possible that you make a manual for it so other users can also benefit from your findings?
Moved to "external control" forum.
Seems more appropriate.
Here is the virtual device as requested,
there are now two virtual devices.
toom connect updated to version 1.25
Toon data version 0.2
toon connect 1.25:
> adjustments on the label naming to provide a beter blok programming experience
> minor bug fixes
> extra functions
toon data 0.23:
displays statics data from the toon.
has beta status.
reply's , ideas are welkom.
toon connect 1.25:
> minor bug fixes
> extra functions
toon data 0.23:
has beta status.
- Toon_Connect_1.25.zip
- toon connect version 1.25
- (5.83 KiB) Downloaded 602 times
- Toon_Data__0.23.zip
- toon data version 0.23
- (2.39 KiB) Downloaded 581 times
Hi, is this VD still working?
Yes they are still working for me.
Toon1 running firmware 5.33.9 (rooted)
Oke thank you for your reply!SDeath wrote:Yes they are still working for me.
Looks great! Installed it but can't figure out which TCD port my Toon uses. Where can I find this? Thanks in advance!
- Administrator
Try port 80 or 10080RubenNL wrote:Looks great! Installed it but can't figure out which TCD port my Toon uses. Where can I find this? Thanks in advance!
I got my HC3 to replace my HC2 last week, and been busy converting everything manually, I have lot's of LUA in my HC.
And also converted the VD by fkruis to a HC3 QuickApp.
I have them attached to this post.
Both QuickApps will start updating within 1 minute and keep doing so every minute automatically.
All functions work like before.
Just change the IP address for each QuickApp in the QuickApp Variables to the IP of your Toon and it should work:
- Toon_Connect_3.1.fqa.zip
- Bug fix for local QuickApp variable change.
- (3.02 KiB) Downloaded 340 times
- Toon_Data_3.0_VAR.fqa.zip
- (2.11 KiB) Downloaded 319 times
Updated my previous post to fix a bug.
Please download 3.1 version of the Connect app.
