Controlling Toon via Pimatic
Postby debans » Fri Jan 11, 2019 3:23 pm
Hello all, i'm new the the domoticaforum, but reading for a while.
Recently i own a Toon, and have rooted it.
I use Pimatic to for home automation https://pimatic.org/
And wanted to control the Toon.
So i used the manual to Controlling Toon via Domoticz to create the manual for Controlling Toon via Pimatic
debans
Re: Controlling Toon via Pimatic
Postby TheHogNL » Fri Jan 11, 2019 4:49 pm
NIce to see a new user adding the Toon to a new home automation platform! Please share the details and the manual.
Postby debans » Fri Jan 11, 2019 5:01 pm
Step 1:
You need to install the following plugins to Pimatic:
  • Cron
  • log-reader
  • shell-execute
Step 2:
To get the actual information from the Toon every minute.
You can change the frequency of crawling the information.
Add the next code to the Rules section:
      "id": "toongetthermostatinfo",
      "name": "ToongetThermostatInfo",
      "rule": "when every 1 minute then execute \"curl -s 'http://192.168.1.111/happ_thermstat?action=getThermostatInfo' | jq '.' > /home/pi/pimatic-app/ToonThermostatInfo\"",
      "active": true,
      "logging": false
Step 3:
Create a LogWatcher divice to get the data from the logfile
To create a LogWatcher device getting and converting the data from the logfile, created by the rule.
Add the next code to the Devices section:
      "id": "toonthermostatinfo",
      "name": "ToonThermostatInfo",
      "class": "LogWatcher",
      "file": "/home/pi/pimatic-app/ToonThermostatInfo",
      "attributes": [
          "name": "currentTemp",
          "type": "number"
          "name": "currentSetpoint",
          "type": "number"
          "name": "programState",
          "type": "string"
          "name": "activeState",
          "type": "string"
          "name": "nextProgram",
          "type": "number"
          "name": "nextState",
          "type": "number"
          "name": "nextTime",
          "type": "number"
          "name": "nextSetpoint",
          "type": "number"
      "lines": [
          "match": ".currentTemp.:..(.+)..",
          "currentTemp": "$1:100"
          "match": ".currentSetpoint.:..(.+)..",
          "currentSetpoint": "$1:100"
          "match": ".programState.:..0..",
          "programState": "Off"
          "match": ".programState.:..1..",
          "programState": "On"
          "match": ".programState.:..2..",
          "programState": "Temporary"
          "match": ".programState.:..4..",
          "programState": "Holiday"
          "match": ".activeState.:..-1..",
          "activeState": "Manual"
          "match": ".activeState.:..0..",
          "activeState": "Comfort"
          "match": ".activeState.:..1..",
          "activeState": "Home"
          "match": ".activeState.:..2..",
          "activeState": "Sleep"
          "match": ".activeState.:..3..",
          "activeState": "Away"
          "match": ".activeState.:..4..",
          "activeState": "Holiday"
          "match": ".nextProgram.:..(.+)..",
          "nextProgram": "$1"
          "match": ".nextState.:..(.+)..",
          "nextState": "$1"
          "match": ".nextTime.:..(.+)..",
          "nextTime": "$1"
          "match": ".nextSetpoint.:..(.+)..",
          "nextSetpoint": "$1"
      "xAttributeOptions": []
Step 4:
Create 2 Variable Devices tho show the statuses
To show the actual temperature and the setpoint temperature
      "id": "toontemp",
      "name": "Toon",
      "class": "VariablesDevice",
      "variables": [
          "name": "temperature",
          "expression": "round($toonthermostatinfo.currentTemp / 100,1)",
          "type": "number",
          "unit": "°C",
          "acronym": "Temp"
          "name": "setpoint",
          "expression": "round($toonthermostatinfo.currentSetpoint / 100,1)",
          "type": "number",
          "unit": "°C",
          "acronym": "Setpoint"
To show the actual status of the active scheme and the program
      "id": "toonschemeinfo",
      "name": "Toon",
      "variables": [
          "name": "state",
          "expression": "$toonthermostatinfo.activeState",
          "label": "Scheme",
          "acronym": "Schema"
          "name": "program",
          "expression": "$toonthermostatinfo.programState",
          "label": "Program",
          "acronym": "Program"
Step 5:
Create 2 Button Devices tho toggle the program and the schemes
To create a button device for turning the auto program on or off.
      "id": "toonprogram",
      "name": "Toon Program",
      "class": "ShellButtons",
      "buttons": [
          "id": "on",
          "text": "On",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=1'"
          "id": "off",
          "text": "Off",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=0'"
To create a button device for the 4 different schemes.
      "id": "toonscheme",
      "name": "Toon",
      "buttons": [
          "id": "SetAway",
          "text": "Away",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=2&temperatureState=3'"
          "id": "SetSleep",
          "text": "Sleep",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=2&temperatureState=2'"
          "id": "SetHome",
          "text": "Home",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=2&temperatureState=1'"
          "id": "SetComfort",
          "text": "Comfort",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=2&temperatureState=0'"
Done
You now have a fully working Toon with Pimatic.
debans
Postby djmvt » Thu Oct 10, 2019 10:48 pm
I've installed a Toon thermostat yesterday and in all my enthusiasm started to put your code in my config.json on pimatic, tried it, got a lot of errors and finally realised I've completely ignored the part where you wrote you rooted your Toon hahaha
But since I want to use Google home speech control with toon rooting is not an option for now, as far as I've seen.
Thanks anyway, I'll save the config.json just in case I want to root the Toon in the future!
djmvt
Postby TerrorSource » Sat Oct 12, 2019 10:16 pm
djmvt wrote:I've installed a Toon thermostat yesterday and in all my enthusiasm started to put your code in my config.json on pimatic, tried it, got a lot of errors and finally realised I've completely ignored the part where you wrote you rooted your Toon hahaha
Why isn't rooting an option? After rooting, the Toon is more compatible with Domotica systems then a non-rooted Toon.
TerrorSource
Postby djmvt » Wed Nov 06, 2019 11:25 pm
TerrorSource wrote:Why isn't rooting an option? After rooting, the Toon is more compatible with Domotica systems then a non-rooted Toon.
Because I will have to figure out how to keep speech control with Google home on a rooted toon. Haven't found any links about that yet but when I do find them I will probably root it :)
djmvt
Return to Toon external control
