Toon for Android
Re: Toon for Android
Postby ams123 » Sat Feb 01, 2020 2:50 pm
From today get this message
On 2 samsung s8
Greetz
Ams
Toon solarpannels
ams123
Postby TerrorSource » Mon Feb 03, 2020 1:44 pm
ams123 wrote:Image
On 2 samsung s8
Greetz
Ams
Well,that's a quite common error.
Was the smartphone connected to same network as the Toon? Was the correct IP used?
If external/outside, was port forwarding being applied to the Toon? Was the correct external IP/DDNS used?
TerrorSource
Postby PeJeWe » Mon Feb 03, 2020 9:20 pm
ams123 wrote:Image
On 2 samsung s8
Greetz
Ams
i have the same error.
i have deleted the app complete with the data and reinstalled it without succes the error keeps coming.
i used it with internal network not outside the network.
PeJeWe
Postby RoadXY » Mon Feb 03, 2020 11:49 pm
ams123 wrote:Image
On 2 samsung s8
Greetz
Ams
Could you provide me the output of
http://[TOON-IP]/hdrv_zwave?action=getDevices.json
RoadXY
Postby crazyfarmer » Wed Feb 05, 2020 12:30 pm
I installed the app and it work's great thanks!
One thing I want to know if it's possible to login with a password to control the toon.
crazyfarmer
Postby RoadXY » Wed Feb 05, 2020 8:58 pm
crazyfarmer wrote:Hi,
Toon doesn't support authentication
RoadXY
Postby PeJeWe » Wed Feb 05, 2020 10:14 pm
RoadXY wrote:
ams123 wrote:Image
On 2 samsung s8
Greetz
Ams
{"dev_settings_device": {"uuid": "927c5a05-dcb1-49f6-a77e-451833a9da64", "name": "settings_device", "internalAddress": "settings_device", "type": "settings_device"}, "dev_4": {"uuid": "3d213533-3be1-488a-bc29-71f3bdc89a84", "name": "HAE_METER_v3", "internalAddress": "4", "type": "HAE_METER_v3", "supportsCrc": "1", "ccList": "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e", "supportedCC": "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e", "nodeFlags": [], "IsConnected": "1", "HealthValue": "10", "DeviceName": "HAE_METER_v3", "CurrentSensorStatus": "UNKNOWN"}, "dev_4.1": {"uuid": "4408e431-fe9b-4f0f-a3c4-7c0b5d13b731", "name": "HAE_METER_v3_1", "internalAddress": "4.1", "type": "HAE_METER_v3_1", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "OPERATIONAL", "CurrentGasFlow": "674.00", "CurrentGasQuantity": "5928062.00", "DeviceName": "HAE_METER_v3_1"}, "dev_4.2": {"uuid": "239a5695-5d99-4441-ba11-582b804bd071", "name": "HAE_METER_v3_2", "internalAddress": "4.2", "type": "HAE_METER_v3_2", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "UNKNOWN", "DeviceName": "HAE_METER_v3_2", "CurrentElectricityFlow": "NaN", "CurrentElectricityQuantity": "NaN"}, "dev_4.3": {"uuid": "e7390fc3-48e5-49df-9682-6bce0e0e512a", "name": "HAE_METER_v3_3", "internalAddress": "4.3", "type": "HAE_METER_v3_3", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "UNKNOWN", "DeviceName": "HAE_METER_v3_3", "CurrentElectricityFlow": "NaN", "CurrentElectricityQuantity": "NaN"}, "dev_4.4": {"uuid": "c8e7fd36-1423-49a0-afc6-234ffb5d6500", "name": "HAE_METER_v3_4", "internalAddress": "4.4", "type": "HAE_METER_v3_4", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "OPERATIONAL", "DeviceName": "HAE_METER_v3_4", "CurrentElectricityFlow": "329.00", "CurrentElectricityQuantity": "8485587.00"}, "dev_4.5": {"uuid": "c3e7c207-2123-4b64-b038-b8ee08c9e6f9", "name": "HAE_METER_v3_5", "internalAddress": "4.5", "type": "HAE_METER_v3_5", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "OPERATIONAL", "DeviceName": "HAE_METER_v3_5", "CurrentElectricityFlow": "0.00", "CurrentElectricityQuantity": "0.00"}, "dev_4.6": {"uuid": "8f2a94ab-cfa9-4b06-a664-2e1b23c652ab", "name": "HAE_METER_v3_6", "internalAddress": "4.6", "type": "HAE_METER_v3_6", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "OPERATIONAL", "DeviceName": "HAE_METER_v3_6", "CurrentElectricityFlow": "0.00", "CurrentElectricityQuantity": "5975086.00"}, "dev_4.7": {"uuid": "536644c2-3124-47fa-8531-085d38ffc64b", "name": "HAE_METER_v3_7", "internalAddress": "4.7", "type": "HAE_METER_v3_7", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "OPERATIONAL", "DeviceName": "HAE_METER_v3_7", "CurrentElectricityFlow": "0.00", "CurrentElectricityQuantity": "0.00"}, "dev_4.8": {"uuid": "52d32292-eba2-4553-8b9b-31ca435a7844", "name": "HAE_METER_v3_8", "internalAddress": "4.8", "type": "HAE_METER_v3_8", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "UNKNOWN", "DeviceName": "HAE_METER_v3_8", "CurrentHeatQuantity": "NaN"}}
That's the output I get from the json code
PeJeWe
Postby RoadXY » Wed Feb 05, 2020 11:25 pm
Any idea why you are at version 4 of your devices?
Did you pair your meter adapter again?
RoadXY
Postby yjb » Thu Feb 06, 2020 6:28 am
yjb wrote:
RoadXY wrote:Just released 0.5.8 to Alpha channel.
This release should fix gas graphs not showing.
Also released 0.5.7 to production (non beta/alpha testers)
Thanks for this, seems that there is some progress
I'm now on Alpha 0.58:
Current gas usage is now working (matches hdrv_zwave/?action=getDevices.json)
Historical gas charts are not working (no chart data available)
Keep up the good work!
How can I help troubleshooting this?
Fro starters:
Samsung S8, Android 9
yjb
Postby crazyfarmer » Thu Feb 06, 2020 6:15 pm
Got it, thanks
crazyfarmer
Postby PeJeWe » Thu Feb 06, 2020 7:53 pm
RoadXY wrote:Any idea why you are at version 4 of your devices?
no, i did not pair my meter adapter again, only updated the toon app on my phone GS270 plus Android 8.
after that i stil get the error message.
then i uninstalled the app complete inc the user data, after that installed it again setup the settings of my toon.
the errors keeps coming.
when i press a button the error appears again.
PeJeWe
Postby RoadXY » Thu Feb 06, 2020 9:16 pm
Fro starters:
Already found the issue, thanks.
Just need time to implement it.
RoadXY
Postby RoadXY » Thu Feb 06, 2020 9:18 pm
Yes, I need to update the app for this.
I'tll be in the next update.
RoadXY
Postby speedyconnalis » Sun Feb 23, 2020 9:56 am
Hi there! I have two different issues on two different phones;
1) Google Pixel 3 (Android 10); App works perfect but at start it sometimes (seems random) turns on WEG (AWAY) mode despite the temperature setting the Toon had at that moment.
2) Samsung S7 (Android 8); App doesn't start. There's a crash right away.
Any tips or tricks? Prefer the Google Pixel issue to be solved since I expect the S7 to be replaced by a newer phone anytime soon. :)
Greets, Tom
speedyconnalis
Postby ams123 » Sun Feb 23, 2020 10:30 pm
yes few times
{"dev_settings_device": {"uuid": "63d744fb-ca4f-43ee-ba6a-befc3ee15c9f", "name": "settings_device", "internalAddress": "settings_device", "type": "settings_device"}, "dev_7": {"uuid": "cc309952-a402-4569-9197-36ca67f86920", "name": "HAE_METER_v3", "internalAddress": "7", "type": "HAE_METER_v3", "supportsCrc": "1", "ccList": "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e", "supportedCC": "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e", "nodeFlags": [], "IsConnected": "1", "HealthValue": "10", "DeviceName": "HAE_METER_v3", "CurrentSensorStatus": "UNKNOWN"}, "dev_7.1": {"uuid": "1f361189-3f05-44f6-ab34-a83e5455d710", "name": "HAE_METER_v3_1", "internalAddress": "7.1", "type": "HAE_METER_v3_1", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "OPERATIONAL", "CurrentGasFlow": "7.00", "CurrentGasQuantity": "2037033.00", "DeviceName": "HAE_METER_v3_1"}, "dev_7.2": {"uuid": "59c1815d-2992-4cc6-a2b7-d7b5335b5062", "name": "HAE_METER_v3_2", "internalAddress": "7.2", "type": "HAE_METER_v3_2", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "UNKNOWN", "DeviceName": "HAE_METER_v3_2", "CurrentElectricityFlow": "NaN", "CurrentElectricityQuantity": "NaN"}, "dev_7.3": {"uuid": "afaaac41-84b8-4992-b7d4-7ab783ae649d", "name": "HAE_METER_v3_3", "internalAddress": "7.3", "type": "HAE_METER_v3_3", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "OPERATIONAL", "DeviceName": "HAE_METER_v3_3", "CurrentElectricityFlow": "0.00", "CurrentElectricityQuantity": "2058.00"}, "dev_7.4": {"uuid": "da0335cb-e95c-4d94-8601-76c32ea65e43", "name": "HAE_METER_v3_4", "internalAddress": "7.4", "type": "HAE_METER_v3_4", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "OPERATIONAL", "DeviceName": "HAE_METER_v3_4", "CurrentElectricityFlow": "0.00", "CurrentElectricityQuantity": "1110057.00"}, "dev_7.5": {"uuid": "c06c31fa-28af-4f2a-917b-f3178ed23298", "name": "HAE_METER_v3_5", "internalAddress": "7.5", "type": "HAE_METER_v3_5", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "UNKNOWN", "DeviceName": "HAE_METER_v3_5", "CurrentElectricityFlow": "0.00", "CurrentElectricityQuantity": "1671074.00"}, "dev_7.6": {"uuid": "795c8d5c-033f-475b-949b-ba84e0e34e84", "name": "HAE_METER_v3_6", "internalAddress": "7.6", "type": "HAE_METER_v3_6", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "UNKNOWN", "DeviceName": "HAE_METER_v3_6", "CurrentElectricityFlow": "453.00", "CurrentElectricityQuantity": "1098472.00"}, "dev_7.7": {"uuid": "f2669dfe-b200-4797-b69f-f648d614fa2e", "name": "HAE_METER_v3_7", "internalAddress": "7.7", "type": "HAE_METER_v3_7", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "UNKNOWN", "DeviceName": "HAE_METER_v3_7", "CurrentElectricityFlow": "0.00", "CurrentElectricityQuantity": "744093.00"}, "dev_7.8": {"uuid": "53624788-63e1-4165-90ce-33115cd73a9e", "name": "HAE_METER_v3_8", "internalAddress": "7.8", "type": "HAE_METER_v3_8", "supportsCrc": "0", "ccList": "5e 59 85 8e 3c 3d 3e", "supportedCC": "5e 59 85 8e 3c 3d 3e", "nodeFlags": [], "CurrentSensorStatus": "UNKNOWN", "DeviceName": "HAE_METER_v3_8", "CurrentHeatQuantity": "NaN"}}
Toon solarpannels
ams123
PreviousNext
Return to Toon external control
