Home Assistant with rooted Toon
dennis071nl
Re: Home Assistant with rooted Toon
Post by dennis071nl »
Guys,
I tried to find a nice solution by searching the forums, but didn't find any solution. I would like to have the tiles that are present on the TOON to be available in my HomeAssistant setup. I've got the HACS components that Ron (cuberjunky) made, so the data does flow in my HA environment. The only thing is the data, it seems like a strange number to me, i would expect something like the tiles for usage of gas and electricity that exist on the TOON.
Anybody tried this before?
Hints/suggestions???
Thanks, Dennis
mAiden
Post by mAiden »
You will have to try it yourself anyway, to get it how you want .. But to help you find the right way, here is a very small piece of my code, how I have incorporated it into it. This is not a sensor, this piece comes from a script that is played every night on my Google Home :)
         {% if states("sensor.toon_volgende_temp_tijd_2") == "2" %}
         Om {{states.sensor.toon_volgende_temp_tijd.state | int | timestamp_custom("%H:%M")}} zal Toon ingesteld worden op Slapen.
         {% elif states("sensor.toon_volgende_temp_tijd_2") == "1" %}
         Om {{states.sensor.toon_volgende_temp_tijd.state | int | timestamp_custom("%H:%M")}} zal Toon ingesteld worden op Thuis.
         {% elif states("sensor.toon_volgende_temp_tijd_2") == "3" %}
         Om {{states.sensor.toon_volgende_temp_tijd.state | int | timestamp_custom("%H:%M")}} zal Toon ingesteld worden op Weg.
         {% elif states("sensor.toon_volgende_temp_tijd_2") == "0" %}
         Om {{states.sensor.toon_volgende_temp_tijd.state | int | timestamp_custom("%H:%M")}} zal Toon ingesteld worden op Comfort.
         {% endif %}
mAiden
Post by mAiden »
Almost got my first page how I want it! :)
ZUID1908
Post by ZUID1908 »
Wow, can you show me how you did that blue (cold) en red (warm) lines? Looks very cool!
X1pheR
Post by X1pheR »
mAiden wrote:Almost got my first page how I want it! :)
Would you mind sharing? Love the layout!
mogwai
Post by mogwai »
Hi guys. I'm moving from Domoticz to Home Assistant and I'm a bit confused what integration to use for my rooted TOON. I see one from mAiden and one from Cyberjunky available via HACS mentioned in this thread. Which one do you guys recommend? Are there any major differences?
Rudolf
Post by Rudolf »
I use Cyberjunky's via HACS. If you look at mAiden's github closely you'll notice that he didn't write it himself and links to the original developer's github.
mAiden hasn't been updated for months. Via HACS works very well, I'd recommend it.
mAiden
Post by mAiden »
Clearly there is a citation in my github post .. Good read, you will find it.
mAiden
Post by mAiden »
ZUID1908 wrote:Wow, can you show me how you did that blue (cold) en red (warm) lines? Looks very cool!
Use the mini graph card for this one. Will be post some things on my github.
TerrorSource
Post by TerrorSource »
After contact with CyberJunky (original writer of the HACS addons for Rooted Toons). He found a method to read the additional Toon2 sensors.
source is toonip/tsc/sensors
sensor:
- platform: rest
name: Toon2 AirSensors
json_attributes:
- humidity
- tvoc
- eco2
value_template: '{{ value_json["temperature"] }}'
unit_of_measurement: "°C"
resource: http://192.168.x.x/tsc/sensors
- platform: template
sensors:
toon2_humidity:
friendly_name: "Humidity"
value_template: '{{ states.sensor.toon2_airsensors.attributes["humidity"] }}'
unit_of_measurement: "%"
toon2_tvoc:
friendly_name: "TVOC"
value_template: '{{ states.sensor.toon2_airsensors.attributes["tvoc"] }}'
unit_of_measurement: "ppm"
toon2_eco2:
friendly_name: "ECO2"
value_template: '{{ states.sensor.toon2_airsensors.attributes["eco2"] }}'
unit_of_measurement: "?"
Source: https://gist.github.com/cyberjunky/6eac ... c6de2450fa
mAiden
Post by mAiden »
TerrorSource wrote:After contact with CyberJunky (original writer of the HACS addons for Rooted Toons). He found a method to read the additional Toon2 sensors.
sensor:
- platform: rest
json_attributes:
- humidity
- tvoc
- eco2
sensors:
toon2_humidity:
toon2_tvoc:
toon2_eco2:
This is also a option:
  - platform: rest
    resource: http://1x.xx.xx.xx/tsc/sensors
    value_template: '{{ value_json["eco2"] }}'
  - platform: rest
    value_template: '{{ value_json["tvoc"] }}'
This one i found by myself, before cyberjunky add it :-)
Snellie1972
Post by Snellie1972 »
I have installed toon_climate trough Hacs but in my dashboard i cannot see the Toon i have in my configuration.yaml the following options
- platform: toon_climate
name: Toon Thermostat
host: 192.168.1.100
port: 80
scan_interval: 10
Do i forget something ??
Thanks in advance
