by FireSon » Fri Jan 17, 2020 6:27 pm
Is it possible to get the humidity from a rooted Toon2? I would like to use it in Home Assistant.
Thanks,
Jan
FireSon
- Starting Member
by TheHogNL » Fri Jan 17, 2020 6:50 pm
Just created a small extra routine in the tsc script which should put info about that in the file
http://toon-ip-address/tsc/sensorsPress 'check update' in tsc menu to get the new script (it will say 'no update found' but it does update the script, there is just no new firmware).
by FireSon » Fri Jan 17, 2020 8:56 pm
Wauw thanks, that is quick and it works
FireSon
- Starting Member
by glsf91 » Mon Jan 20, 2020 9:12 pm
TheHogNL wrote:Just created a small extra routine in the tsc script which should put info about that in the file
I don't know if it can be changed but should Content-Type: application/octet-stream in the response not be Content-Type: application/json
In chrome it wants to save a file when requested.
glsf91
by mAiden » Mon Jan 20, 2020 9:56 pm
glsf91 wrote:TheHogNL wrote:Just created a small extra routine in the tsc script which should put info about that in the file
Dokt change it Thehog. Otherwise Home Assistant will be crash.
mAiden
by RoadXY » Wed Jan 22, 2020 12:27 pm
Are there any sensors on a Toon v1 which can be read?
RoadXY
Return to Toon external control
