(Solved) After upgrade (5.43.2) webserver is not starting
bassie001
Post by bassie001 »
After upgrading my (rooted) toon to version 5.43.2 lighttpd is not starting and remote (mobile) access is not working anymore.
After some digging and manually starting the lighttpd:
/usr/sbin/lighttpd -D -m /usr/lib/lighttpd -f /qmf/etc/lighttpd/lighttpd.conf
2021-05-27 21:14:56: (/home/jenkins/workspace/oe/build-qmf-snapshot/oe/build/tmp/work/cortexa9hf-vfp-neon-angelica-linux-gnueabi/lighttpd/1.4.35-r6/lighttpd-1.4.35/src/configfile.c.957) source: /qmf/etc/lighttpd/lighttpd.conf line: 54 pos: 2 parser failed somehow near here: }
seems like the /qmf/etc/lighttpd/lighttpd.conf is not correct anymore:
/qmf/etc/lighttpd# diff lighttpd.conf lighttpd.conf.lastversion
--- lighttpd.conf
+++ lighttpd.conf.lastversion
@@ -46,6 +46,14 @@
 server.document-root = "/qmf/www"
+$HTTP["remoteip"] !~ "localhost|127.0.0.1|192.168.2.139" {
+    $HTTP["url"] =~ "^/happ_thermstat/" {
+      url.access-deny = ( #"" )
+  ""              =>      "application/json",
 ## where to send error-messages to
 server.errorlog             = "/tmp/lighttpd_error.log"
@@ -111,7 +119,8 @@
   ".tbz"          =>      "application/x-bzip-compressed-tar",
   ".tar.bz2"      =>      "application/x-bzip-compressed-tar",
   # default mime type
-  ""              =>      "application/octet-stream",
+  #""              =>      "application/octet-stream",
 # Use the "Content-Type" extended attribute to obtain mime type if possible
Ps. lastversion is the incorrect latest version.
After replacing the old version everything started correctly.
Re: (Solved) After upgrade (5.43.2) webserver is not starting
Post by TheHogNL »
That is a patch from update script went wrong due to some modification on the older ligghtpd.conf by yourself (adding the url.accessdeny)
