Smokedetector app not disabled after FW update
Postby Templar » Thu May 21, 2020 11:24 am
I disabled all the standard Toon apps in the TSC menu. But after a FW update the Smokedetector app is visible but still disabled in the TSC menu.
A quick fix is to enable and then immediately disable the Smokedetector app and then reboot the GUI. I needed to do this after several updates.
Templar
Re: Smokedetector app not disabled after FW update
Postby TheHogNL » Thu May 21, 2020 2:06 pm
Ok i'll check that when I have some spare time. No priorities.
Postby Templar » Sun Nov 01, 2020 5:01 pm
I don't have that issue anymore with the Smokedetector app. But the Status Usage app has the same problem.
And could the Slim Verwarmen app also added to the list?
Templar
Postby Daniel » Mon Nov 02, 2020 2:06 pm
You can also turn it off yourself. Change in /qmf/qml/config/TenantSettings.json "appHeatingOverviewEnabled" to 'false'. (Thanks to thehognl)
Daniel
Postby Templar » Sat Nov 28, 2020 5:56 pm
Daniel wrote:You can also turn it off yourself. Change in /qmf/qml/config/TenantSettings.json "appHeatingOverviewEnabled" to 'false'. (Thanks to thehognl)
Yes, that got rid of the "Slim verwarmen" app. Thanks! The "Status verbruik" app is still loaded though.. Can anybody tell me which app to disable?
TenantSettings.json
        "appWeather": "",
        "appGraphTileLowestUsage": true,
        "i18nLocales": [
                "nl_NL",
                "en_GB"
        "appWhatIsNewAutostart": false,
        "enabledHeatingSourceConfiguration": false,
        "enabledGasMeterConfiguration": false,
        "appEMetersSettingsAdvancedDisabled": false,
        "appSystemSettingsFactoryResetDisabled": false,
        "appControlPanelSmartplugHardRemoveDisabled": false,
        "appControlPanelPinProtectRemoveBridge": false,
        "appControlPanelLampRenameDisabled": false,
        "appControlPanelPlugRenameDisabled": false,
        "appControlPanelHueSceneSaveDisabled": false,
        "featSMEEnabled": true,
        "featShowEnergyMeterImages": true,
        "featHolidayOffPeakEnabled": true,
        "featSmokeDetectorSensitivityEnabled": true,
        "featAlarmControlEnabled": true,
        "featHumidityEnabled": true,
        "featContactSettingsTabEnabled": true,
        "appSolarEnabled": true,
        "appBenchmarkEnabled": false,
        "appWhatIsNewEnabled": false,
        "appWhatIsToonEnabled": false,
        "appSmokeDetectorEnabled": false,
        "appHeatRecoveryEnabled": false,
        "appCustomerServiceEnabled": false,
        "appInboxEnabled": true,
        "appUpsellEnabled": false,
        "appHeatingOverviewEnabled": false,
        "installationWizardApps": [
                "internet|true",
                "activation|true",
                "update|false",
                "emeters|false",
                "boiler|false"
        "appBoilerMonitorEnabled": false,
        "appStatusUsageEnabled": false
Templar
Return to Toon software development
