Copy Historical data (rra databases) between Toons
oepi-loepi
Re: Copy Historical data (rra databases) between Toons
Post by oepi-loepi »
Did you enable the zon of toon feature on the new toon ? Setup tsc features zon-op-toon ?
Als do you see solar files in the export folder? If so try again with the solar files only. It should work (has been tested).
hafeez
Post by hafeez »
Never mind. I managed to get it working.
I had to connect my Zon op Toon analog meter first with my new Toon2 and wait for some graph to be generated on the Toon2.
Now I could see all my historical solar panels data after another import
However, on the total page it showed an incorrect value for the solar panel power generated and a date which was close to the date I bought this Toon2.
I had to change the installedDate in /mnt/data/qmf/config/config_happ_pwrusage.xml to a value which represented the date I installed my Zon op Toon
Once changed, the total solar panel power generated was correct.
Thanks for this program. I can finally use my Toon2 after having it laying in the closet for 2 years.
gerlag
Post by gerlag »
Hi all, just to let you know.
I was experimenting with logging the heat output from my heat pump using the old gas sensor (I'm using p1 now from the slimme meter) , and unexpectedly extremely high volumes appeared in the logging of the gas quantity. (2800 m3 in just a few hours). Tried to figure out how to repair/modify the wrong values as this had huge influence on the statistics.
Quite an issue to dig into the database.
Then I found the easy way, using the windows app of oepi-loepi based on Toonz method in this thread.
This is what I did:
I exported all csv files from Toon, took both gas quantity files apart and put them in a separate directory. Then, using notepad++, I edited both csv files, changed the values behind the timestap to values that fit into the range of the adjacent values. In my case, for the daily file I had to change just one line, for the hourly file it was 17 lines.
After that I pointed the 'ToonConvert' program to the directory with these two modified csv files in it and imported it into my Toon.
Problem solved. No extremely high spikes in the statistics anymore.
A bit off topic: As a side effect I found that it is possible to import heat quantity into Toon using the url
http://<toon-ip>/hcb_rrd?action=setRrdData&loggerName=heat_quantity&rra=5yrhours&samples={<epoch>:<value>}
I think that I can use this method with some external hard/software.
Arnout2000
Post by Arnout2000 »
Hi @oepi-loepi,
I used your application to copy my gas/electicity/solar history from my broken Toon to my new one. Fantastic App! Great work!
On the tiles, all my historic data is shown.
The only question is about the Zonnepanelen app. Although the tab Month (Feb) and Year (2023) look good, the Total tab used to display all the data since I started with my solar panels (18 MWh) and now it only seems to shows the data since I ran the copy script. Did I miss a step somewhere?
oepi-loepi
Yes, you first have to make sure you have all sensors set up right (electric, gas and solar). Ik you see some data, then use the tool. You can run the app again with only the solar databases.
Arnout2000
I know, but all my historical solar data was already succesfully imported. See this information on 2022:
It is only the information in the Zonnepanelen app which doesn't seem to take the historical data into account...
oepi-loepi
I do not know where that app takes the data from..
oepi-loepi
Maybe hou can change the start date of the solar panel installation somewhere in the xml files, maybe toon uses that as starting date for the calculations from the databases.
All like mentioned here:
viewtopic.php?p=98175#p98175
Arnout2000
Yes, manually correcting the InstalledDate in the file: config_happ_pwrusage.xml did the trick so all data is correct now.
Thanks!
