Toon 1 keeps rebooting (5.46.4)
Re: Toon 1 keeps rebooting (5.46.4)
Postby jnieuw » Fri Dec 31, 2021 12:57 pm
TheHogNL wrote:
jnieuw wrote:Uptime: 29 days
And there is definitely a memory leak somewhere:
Mem: 123340K used, 2856K free, 256K shrd, 0K buff, 34752K cached
CPU: 4.3% usr 5.1% sys 0.0% nic 90.3% idle 0.0% io 0.0% irq 0.1% sirq
Load average: 0.43 0.25 0.17 1/99 29178
I've lost 9000K memory somewhere doing nothing.
Any idea how to find the cause?
Laat eens een 'top -b -n 1' output zien hier
Sorry for the late response, did not get a notification...
I just updated to 5.49.7 and will keep an eye on that one first, then I will post the results.
jnieuw
Postby jnieuw » Fri Dec 31, 2021 1:08 pm
Just for the info 5.49.7 with
top -b -n 1
, after a reboot and (re)disabling the not used services:
Mem: 108260K used, 17936K free, 84K shrd, 0K buff, 35692K cached
CPU: 15.7% usr 31.5% sys  0.0% nic 52.6% idle  0.0% io  0.0% irq  0.0% sirq
Load average: 0.41 0.43 0.20 3/103 1894
  PID  PPID USER     STAT   VSZ %VSZ %CPU COMMAND
1890  1868 root     R     3088  2.4 15.7 top -b -n 1
  759     1 root     S     173m140.0  0.0 {hcb_comm} HCBv2 hcb_comm       [OK] [10 clients] [S1|N1]
  755     1 root     S     167m135.7  0.0 /qmf/sbin/qt-gui -platform linuxfb -plugin Tslib
  762     1 root     S    34480 27.2  0.0 {happ_thermstat} HCBv2 happ_thermstat [OK] [S20|N1]
  769     1 root     S    25780 20.3  0.0 {hcb_config} HCBv2 hcb_config     [OK] [S1|N1]
  758     1 root     S    23164 18.3  0.0 {hcb_netcon} HCBv2 hcb_netcon     [OK] [S1|N1]
  761     1 root     S    23064 18.2  0.0 {happ_scsync} HCBv2 happ_scsync    [OK] [S1|N1]
  760     1 root     S    21952 17.3  0.0 {happ_eventmgr} HCBv2 happ_eventmgr  [OK] [S1|N1]
  768     1 root     S    21892 17.3  0.0 {happ_usermsg} HCBv2 happ_usermsg   [OK] [S1|N1]
  770     1 root     S    21220 16.7  0.0 {hcb_watchdog} HCBv2 hcb_watchdog   [OK] [S20|N1]
  771     1 root     S    14056 11.1  0.0 /usr/sbin/lighttpd -D -m /usr/lib/lighttpd -f /qmf/etc/lighttpd/lighttpd.conf
1215     1 root     S     4176  3.3  0.0 /usr/sbin/wpa_supplicant -B -P /var/run/wpa_supplicant.wlan0.pid -i wlan0 -c /etc/network/wpa_supplicant.wlan0.conf -D wext
1868  1825 root     S     3264  2.5  0.0 -sh
  756     1 root     S     3092  2.4  0.0 /sbin/getty -L 115200 ttymxc0 vt102
  757     1 root     S     3088  2.4  0.0 {tsc} /bin/sh /usr/bin/tsc
  703     1 root     S     3088  2.4  0.0 /sbin/syslogd -n -O /var/log/messages -s 32 -b 1 -m 20
  706     1 root     S     3088  2.4  0.0 /sbin/klogd -n
1275     1 root     S     3088  2.4  0.0 udhcpc -b -R -i eth0 -A 5 -p /var/run/udhcpc.eth0.pid -H eneco-001-097000
1891   758 root     S     3088  2.4  0.0 sh -c PATH=/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:$PATH ps | grep 'config /etc/openvpn/vpn.conf' | grep -v grep
1242     1 root     S     3088  2.4  0.0 udhcpc -R -n -p /var/run/udhcpc.wlan0.pid -i wlan0 -x hostname:eneco-001-097000 -t 2
1889   757 root     S     2956  2.3  0.0 sleep 5
1257     1 root     S     2508  1.9  0.0 /usr/sbin/chronyd -r
1825   697 root     S     2440  1.9  0.0 /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
  697     1 root     S     2268  1.7  0.0 /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
  711     1 root     S     1876  1.4  0.0 /usr/sbin/cron
    1     0 root     S     1704  1.3  0.0 init [5]
  608     2 root     SW       0  0.0  0.0 [RtmpMlmeTask]
  607     2 root     SW       0  0.0  0.0 [RtmpTimerTask]
    3     2 root     SW       0  0.0  0.0 [ksoftirqd/0]
    5     2 root     SW       0  0.0  0.0 [kworker/u:0]
  236     2 root     SW       0  0.0  0.0 [kworker/0:1]
  136     2 root     SW       0  0.0  0.0 [khubd]
  609     2 root     SW       0  0.0  0.0 [RtmpCmdQTask]
  309     2 root     SW       0  0.0  0.0 [ubi_bgt0d]
  573     2 root     SW       0  0.0  0.0 [flush-ubifs_0_0]
    2     0 root     SW       0  0.0  0.0 [kthreadd]
    6     2 root     SW       0  0.0  0.0 [watchdog/0]
    7     2 root     SW<      0  0.0  0.0 [khelper]
    8     2 root     SW       0  0.0  0.0 [kworker/u:1]
   11     2 root     SW<      0  0.0  0.0 [pm]
  119     2 root     SW       0  0.0  0.0 [sync_supers]
  121     2 root     SW       0  0.0  0.0 [bdi-default]
  123     2 root     SW<      0  0.0  0.0 [kblockd]
  235     2 root     SW<      0  0.0  0.0 [rpciod]
  243     2 root     SW       0  0.0  0.0 [khungtaskd]
  244     2 root     SW       0  0.0  0.0 [kswapd0]
  245     2 root     SW       0  0.0  0.0 [fsnotify_mark]
  246     2 root     SW<      0  0.0  0.0 [nfsiod]
  247     2 root     SW<      0  0.0  0.0 [crypto]
  264     2 root     SW       0  0.0  0.0 [kworker/0:2]
  281     2 root     SW       0  0.0  0.0 [mtdblock0]
  286     2 root     SW       0  0.0  0.0 [mtdblock1]
  291     2 root     SW       0  0.0  0.0 [mtdblock2]
  296     2 root     SW       0  0.0  0.0 [mtdblock3]
  301     2 root     SW       0  0.0  0.0 [mtdblock4]
  310     2 root     SW<      0  0.0  0.0 [spi_imx.0]
  358     2 root     SW       0  0.0  0.0 [ubifs_bgt0_0]
jnieuw
Postby EJanus » Fri Jan 07, 2022 12:18 pm
I've been having the same problem for a month now. Toon1 reboots several times a day.
I have uninstalled the unnecessary apps. The tone is practically bare. Only the agenda app and the buienradar app from the Toonstore. I also use the power meter module. That is it.
I just can't figure out what triggers the reboot.
EJanus
Postby oepi-loepi » Fri Jan 07, 2022 11:22 pm
EJanus wrote:I've been having the same problem for a month now. Toon1 reboots several times a day.
I remove the libqt5websockets (all 3) with a -f . See opkg list-instlled it seems to help. Can you check if it helps for you also?
oepi-loepi
Postby Bruce the boss » Sat Jan 08, 2022 1:46 pm
It's not clear or me which files you can remove when your Toon is reboting "several times" day.
What I understand is that ypu can remove files in the directory qmf/etx/start.d/ from that apps you dont use.
I do have the underneath files in that directory:
happ_eventmgr
happ_pwrusage
happ_scsync
happ_smartplug
happ_thermstat
happ_usermsg
hcb_bxtproxy
hcb_config
hcb_rrd
hcb_watchdog
hdrv_hue
hdrv_p1
hdrv_zwave
lighttpd
And which log files can be removed?
I removed them all but then at least the watermeter is not working:
01_GENERAL.log.json
04_DEVICE.log.json
06_ALARM.log.json
09_THERMO.log.json
10_CONNECTION.log.json
11_ASSET.log.json
90__UNKNOWN_.log.json
92__UNKNOWN_.log
93__UNKNOWN_.log
94__UNKNOWN_.log
96__UNKNOWN_.log
97__UNKNOWN_.log
98__UNKNOWN_.log
99_DEBUG.log
I'm working with the apps:
Buienradar
Watermeter
afvalkalender
Which files can be removed safely (I will save them also on my laptop)?
Bruce the boss
Postby oepi-loepi » Sat Jan 08, 2022 6:57 pm
Well i mean remove some installed websockets packages. The packages are installed during updates and are needed for applications like the Onkyo controller app and the thermostat plus app. You do not have those apps installed and websockets are not needed. Just to try... could you try to remove the websockets and let us know if the toon gets better?
To remove with ssh (like putty):
If you enter the toon with ssh (putty). Please try the following commands:
opkg list-installed libqt5webs*
you will receive a list with the installed websockets packages:
libqt5websockets-plugins - 5.11.2+git0+e71467cb56-r0
libqt5websockets-qmlplugins - 5.11.2+git0+e71467cb56-r0
libqt5websockets5 - 5.11.2+git0+e71467cb56-r0
remove each of them:
opkg remove libqt5websockets-plugins --force-removal-of-dependent-packages
After that reboot the toon.
To reinstall the packages just update the toon or force an update:
sh update-rooted.sh -v with the current version of the toon (do not downgrade!)
so if your current version is 5.49.7 just execute sh update-rooted.sh -v 5.49.7
oepi-loepi
Postby Bruce the boss » Sat Jan 08, 2022 9:09 pm
When I delete them the water usage chart isn't working. Is this related to that files?
Verstuurd vanaf mijn SM-G950F met Tapatalk
Bruce the boss
Postby oepi-loepi » Sat Jan 08, 2022 9:35 pm
Bruce the boss wrote:When I delete them the water usage chart isn't working. Is this related to that files?
No, not at all. Water is not using websockets. I checked and after removing i still have the charts.
oepi-loepi
Postby Bruce the boss » Sun Jan 09, 2022 1:31 pm
Problem solved. I think I removed too much files.
Bruce the boss
Postby brommetje » Sun Jan 09, 2022 4:34 pm
Hi @Bruce the boss can you make some kind of overview witch files you removed?
brommetje
Postby EJanus » Sun Jan 09, 2022 4:58 pm
Tank you @oepi-loepi for your help en detailed instructions!
I removed the packages mentioned by you and rebooted Toon. I'll check if this fixes the random reboots and report my findings later.
EJanus
Postby Bruce the boss » Sun Jan 09, 2022 6:58 pm
brommetje wrote:Hi @Bruce the boss can you make some kind of overview witch files you removed?
The above files
Bruce the boss
Postby EJanus » Sat Jan 15, 2022 11:47 am
Unfortunately the suggested solution did not help me. I still experience multiple reboots per day.
This is my top -b -n 1 output:
Mem: 120696K used, 5500K free, 112K shrd, 0K buff, 27576K cached
CPU:  0.0% usr 23.0% sys  0.0% nic 76.9% idle  0.0% io  0.0% irq  0.0% sirq
Load average: 0.29 0.32 0.34 1/126 6462
6462  5513 root     R     3088  2.4 15.3 top -b -n 1
  769     1 root     S     253m204.8  0.0 {hcb_comm} HCBv2 hcb_comm       [OK] [15 clients] [S1|N1]
25192     1 root     S     183m148.1  0.0 /qmf/sbin/qt-gui -platform linuxfb -plugin Tslib
  783     1 root     S    39924 31.5  0.0 {hdrv_zwave} HCBv2 hdrv_zwave     [OK] [D4185B4A SIS 3.67] [S1|N1]
  776     1 root     S    34480 27.2  0.0 {happ_thermstat} HCBv2 happ_thermstat [OK] [ON/OFF] [S20|N1]
  782     1 root     S    34436 27.2  0.0 {hdrv_p1} HCBv2 hdrv_p1        [OK] [C:OK E:OP (P1) G:OP (P1) ] [S1|N1]
  780     1 root     S    32028 25.3  0.0 {hcb_rrd} HCBv2 hcb_rrd        [OK] [S1|N1]
  773     1 root     S    26960 21.3  0.0 {happ_pwrusage} HCBv2 happ_pwrusage  [OK] [S1|N1]
  778     1 root     S    26764 21.1  0.0 {hcb_config} HCBv2 hcb_config     [OK] [S1|N1]
  768     1 root     S    23164 18.3  0.0 {hcb_netcon} HCBv2 hcb_netcon     [OK] [S1|N1]
  774     1 root     S    23064 18.2  0.0 {happ_scsync} HCBv2 happ_scsync    [OK] [S1|N1]
  777     1 root     S    22916 18.1  0.0 {happ_usermsg} HCBv2 happ_usermsg   [OK] [S1|N1]
  772     1 root     S    21952 17.3  0.0 {happ_eventmgr} HCBv2 happ_eventmgr  [OK] [S1|N1]
  775     1 root     S    21332 16.8  0.0 {happ_smartplug} HCBv2 happ_smartplug [OK] [S1|N1]
  781     1 root     S    21220 16.7  0.0 {hcb_watchdog} HCBv2 hcb_watchdog   [OK] [S20|N1]
  788     1 root     S    14056 11.1  0.0 /usr/sbin/lighttpd -D -m /usr/lib/lighttpd -f /qmf/etc/lighttpd/lighttpd.conf
2044     1 root     S     4176  3.3  0.0 /usr/sbin/wpa_supplicant -B -P /var/run/wpa_supplicant.wlan0.pid -i wlan0 -c /etc/network/wpa_supplicant.wlan0.conf -D wext
5513  5494 root     S     3264  2.5  0.0 -sh
  766     1 root     S     3092  2.4  0.0 /sbin/getty -L 115200 ttymxc0 vt102
  767     1 root     S     3088  2.4  0.0 {tsc} /bin/sh /usr/bin/tsc
2073     1 root     S     3088  2.4  0.0 udhcpc -b -R -i eth0 -A 5 -p /var/run/udhcpc.eth0.pid -H eneco-001-004417
  713     1 root     S     3088  2.4  0.0 /sbin/syslogd -n -O /var/log/messages -s 32 -b 1 -m 20
  715     1 root     S     3088  2.4  0.0 /sbin/klogd -n
2101     1 root     S     3088  2.4  0.0 udhcpc -b -R -i wlan0 -A 5 -p /var/run/udhcpc.wlan0.pid -H eneco-001-004417
6461   767 root     S     2956  2.3  0.0 sleep 5
29162     1 root     S     2748  2.1  0.0 /usr/sbin/chronyd -r
5494   706 root     S     2440  1.9  0.0 /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
  706     1 root     S     2268  1.7  0.0 /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
  757     1 root     S     1876  1.4  0.0 /usr/sbin/cron
  570     2 root     SW       0  0.0  0.0 [flush-ubifs_0_0]
  359     2 root     SW       0  0.0  0.0 [ubifs_bgt0_0]
2041     2 root     SW       0  0.0  0.0 [RTKTHREAD]
2978     2 root     SW       0  0.0  0.0 [kworker/0:1]
5289     2 root     SW       0  0.0  0.0 [kworker/0:2]
6000     2 root     SW       0  0.0  0.0 [kworker/0:0]
I'm stuck. Anyone any ideas?
EJanus
Postby oepi-loepi » Sat Jan 15, 2022 5:25 pm
Which custum apps did you install?
oepi-loepi
Postby EJanus » Sat Jan 15, 2022 5:48 pm
Only the Toonstore with the Buienradar and calender app.
EJanus
PreviousNext
