Rooted Toon stuck in install mode
AJAPPELDOORN
Post by AJAPPELDOORN »
Help, I have a rooted Toon but its stuck in the installation mode.
I cant pass or go further without a activation code from Eneco.
Re: Rooted Toon stuck in install mode
You can fix that with the update-rooted.sh script. See elsewhere on this forum for details.
AJAPPELDOORN
marcelr wrote:You can fix that with the update-rooted.sh script. See elsewhere on this forum for details.
Thanks, I’ve tried: curl -Nks https://raw.githubusercontent.com/IgorY ... -rooted.sh -o /root/update-rooted.sh
You are currently running version 5.0.4 on a qb2 with flavour uni
Available versions: 1.0.9 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.15 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.11.6 4.12.0 4.13.6 4.13.7 4.15.2 4.15.6 4.16.8 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4
Which version do you want to upgrade to?
Seems I already have the latest version…
yjb
Post by yjb »
update-rooted.sh can also "fix"fiiles which are not correct (without any update):
update-rooted.sh -f
TerrorSource
Post by TerrorSource »
Didn't you need the manual/help before running it?
Tru using the "update-rooted.sh -h" to show help information. solution is right there!
AJAPPELDOORN
problem solved ;) super thanks to all
robgeerts
Post by robgeerts »
IS there a solution for this if someone else rooted for you and you cant remember who this was?
I dont have cables to connect myself....
WickedMaster
Post by WickedMaster »
robgeerts wrote:IS there a solution for this if someone else rooted for you and you cant remember who this was?
If you have forgotten your SSH password, you have to root it again.
Post by TheHogNL »
If you have the TSC menu you can reset the password there. The TSC menu is available from updates 4.16 and further for rooted toons as a mod in the resource files.
TerrorSource
Isn't there a sticker on the back side of the Toon as some rooters/sellers do that :)
robgeerts
Post by robgeerts »
I know the password...
BUT i can only see the install menu... so not any additional icons..
SSH seems not be acessible when i try to connect? Or do i miss something here..
WickedMaster
Then your Toon isn't rooted. You have to root the Toon, or let it do.
robgeerts
Post by robgeerts »
It was rooted!
I had appstore and installed some apps. Untill I did a factory reset.
This resets the root too?
Versions at the time of rooting:
Software: 4.8.25
Firmware ketelmodule: 37
Firmware meteradapter: 35/37​
Post by TheHogNL »
robgeerts wrote:I know the password...
If it was rooted it is still rooted even after a factory reset. But after a factory reset you need to set the wifi first or else you can't connect ofcourse.
robgeerts
Post by robgeerts »
The wifi is set. The api calls the Domoticz use to set temperature are working.
So even SSH should still work after factory reset? Even in my version?
