Question, where on the Toon is stored the actual usage (gas an electricity) info that is displayed on the Toon.
I have found the log files but those used as far I see, after the values are showed on the live "view" on the display.
Stored usage information
__________________
Re: Stored usage information
Local on Toon you find it in: /qmf/var/hcb_rrd
But you can't nothing with it.
If you want to import it to a other program, then you need have to access via HTTP to you're Toon.
Go to:
http://YOURIPOFTOON(change this to IP of Toon)/hdrv_zwave?action=getDevices.json
you will receive a lot of information, you will have to look at your meter adapter that transmits gas and electricity.
Go to:
