Domoticz integration broken after update to Toonstore 5.0
Postby Tomm1ed » Wed Dec 11, 2019 12:08 pm
This morning I saw there was an update for Toonstore so decided to update. from 3.x to 5.0. After the reboot Domoticz can no longer connect to Toon.
I am receiving this error:
2019-12-11 11:44:05.857 Error: EventSystem: in Toon: /home/tomm1ed/domoticz/scripts/lua/JSON.lua:660: html passed to JSON:decode(): <?xml version="1.0" encoding="iso-8859-1"?>
2019-12-11 11:44:05.857 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
2019-12-11 11:44:05.857 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
2019-12-11 11:44:05.857 <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
2019-12-11 11:44:05.857 <head>
2019-12-11 11:44:05.857 <title>403 - Forbidden</title>
2019-12-11 11:44:05.857 </head>
2019-12-11 11:44:05.857 <body>
2019-12-11 11:44:05.857 <h1>403 - Forbidden</h1>
2019-12-11 11:44:05.857 </body>
Opening http://[toonip]/happ_thermstat?action=getThermostatInfo in a browser also returns 403 - Forbidden
I am running Toon 5.13.12. (Since the last time I upgraded the Firmware my Toon was bricked (https://www.domoticaforum.eu/viewtopic. ... 555#p91949) and currently it's very cold I am a bit hesitant to upgrade the firmware, so I hope there is a fix for this without having to do a firmware update)
Tomm1ed
Re: Domoticz integration broken after update to Toonstore 5.0
Postby TheHogNL » Wed Dec 11, 2019 1:52 pm
Updating toonstore has nothing to do with the internal webpage of the toon.
I think some other settings are wrong. Try to run the update script (update-rooted.sh) with option -f which does not update but only fixes necessary files on rooted toons
Postby Tomm1ed » Wed Dec 11, 2019 2:15 pm
TheHogNL wrote:Updating toonstore has nothing to do with the internal webpage of the toon.
I'm not saying that there is a relationship, however everything was working until I updated Toonstore. This auto-rebooted the Toon1 and after that the page gave back a 403. Toon1 has been working fine with Domoticz since you fixed it last september.
sh update-rooted.sh -f
Version: 4.10  - TheHogNL & TerrorSource & yjb - 6-12-2019
If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
Only fixing files.
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.13.12.
EDITING: disabling Eneco subscription feature apps to free up memory on this toon 1
EDITING: disabling samba nmbd on toon 1 as probably it is not necessary
Website still returns 403, I do notice value enforcewhistlist under hcb_web in /qmf/etc/qmf_release.xml is now set to 0. Do I need to reboot the Toon for it to take effect?
Tomm1ed
Postby TheHogNL » Wed Dec 11, 2019 2:31 pm
Tomm1ed wrote: Do I need to reboot the Toon for it to take effect?
Short answer yes. Long answer, you could restart some processes like hcb_config and lighttpd so the config gets read and applied :-)
Postby Tomm1ed » Wed Dec 11, 2019 2:44 pm
Thank you! After reboot the 403 is gone. Still wondering what happened. Maybe the lesson is if it ain’t broke don’t try to fix it ;)
Tomm1ed
Postby TheHogNL » Wed Dec 11, 2019 4:27 pm
I checked and found an error in the toonstore removal (before upgrade to toonstore 5) which sets the enforceWhitelist back to 1.
Just published a fix for that.
Postby Tomm1ed » Wed Dec 11, 2019 5:26 pm
TheHogNL wrote:I checked and found an error in the toonstore removal (before upgrade to toonstore 5) which sets the enforceWhitelist back to 1.
Ah great thank you! Glad I’m not crazy :p
Tomm1ed
Return to Toon issues and support (Nederlands toegestaan)
