Upgrade path firmware 1.8.10 to current
Kjors
Post by Kjors »
I got a new toon, the history is unkown, But it turned out to be and old one. It runs u-boot R4, and firmware 1.8.10.
It says "textexemplaar' on the back, and its not activated.
Rooting was successful.
Running update-rooted.sh -f gives a lot of errors, missing files.
Same for update-rooted.sh -a, missing files and does not work.
So my next step would be updating, but should use a update path? Or directly to the latest version?
Thanks,
Kjors
Re: Upgrade path firmware 1.8.10 to current
Post by TheHogNL »
Is there a working VPN? I guess not. Most of those old toons don't have that anymore. But if it does, let us show the logs of the update script.
If not, you could do a toonrecovery to get it up to 5.0.6.
Or paste a openvpn key from another toon and maybe that works. But the toonrecovery way is much faster.
TerrorSource
Post by TerrorSource »
Woow firmware 1.8.10? Thats like from the stone-ages :lol:
My guess is that you cant update it due to the fact that the VPN-keys are revoked as they did that to all "testexemplaren" a while ago.
Kjors
Post by Kjors »
There are certs in /etc/openvpn/vpn, but they dont work, looking at the log.
I will look a toonrecovery to 5.0.6, later this week.
So the "testexemplaren" are normal versions, delivered to customers?
Log of the failed attempt.
You are currently running version 1.8.10 on a qb2 with flavour enw
Available versions: 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.15 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.10.9 4.11.6 4.12.0 4.13.6 4.13.7 4.15.2 4.15.6 4.16.8 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4 5.0.5 5.0.6 5.2.11 5.5.7 5.9.6 5.13.9 5.13.12 5.15.6 5.18.8 5.22.14 5.25.8 5.28.6 5.28.9 5.30.4 5.33.9
Which version do you want to upgrade to?
5.0.6
Alright, I will try to upgrade to 5.0.6
Could not enable VPN in a normal reasonable time!
DEBUG information:
192.168.0.0/24 dev eth0 scope link  src 192.168.0.59
default via 192.168.0.1 dev eth0
default via 192.168.0.1 dev eth0  metric 10
# <persistent /etc/hosts content can be added to /etc/hosts.template file>
127.0.0.1               localhost.localdomain           localhost               qb2-enet-0376
172.16.0.1              feed.hae.int            feed
127.0.0.1    ping.quby.nl
END DEBUG information
TerrorSource
These Toon1's are test examples send to specific customers at the start of Toon or send to partners/cv-boiler manufacturers for testing. I even heard that some ISP's received some.
you might be able to do a ToonRecovery to 5.0.6 but you cant update further as the VPN-keys do not work.
Let me know if you need some VPN keys, i can give them for a small fee and help you re-name the Toon the correct way so you can use and update it.
Kjors
Post by Kjors »
So I found a hidden gem, which I don't want. Wile back I bought one which is in use, and I am hesitant to update. Its on 2.x and its in use. I guess I have working VPN keys. Maybe I will come back at that statement.
so two question remain, one on each toon.
Is my hesitancy justified about updating a 2.x toon? The script has 2 steps, to 5.0.4, and 5.25.8.
I cant find information about the steps to re-name a toon. Are you willing to share that information? Can't send a pm yet.
Thanks
Post by TheHogNL »
Kjors wrote:So I found a hidden gem, which I don't want. Wile back I bought one which is in use, and I am hesitant to update. Its on 2.x and its in use. I guess I have working VPN keys. Maybe I will come back at that statement.
Thanks
2.x can be updated (if working vpn keys), it will first go to 5.0.4 (or was it 5.0.6). If it goes bad.. no worries. Toonrecovery is always available and it can restore your vpn keys if it is still on the toon internal storage.
Renaming is easy. Just set correct hostname (which you can find in the vpn key config) in: /etc/hostname /etc/hosts and /etc/network/interfaces
