Toon Store Incorrect app counter
Doerakker
Post by Doerakker »
Adding a new app shows “Toon Bijwerken (1)” as expected
Removing installed app then results in “Toon Bijwerken (0)”
The app update counter returns the net app count. Suggest to modify the counter to display the install/remove
TerrorSource
Re: Toon Store Incorrect app counter
Post by TerrorSource »
Doerakker wrote:Adding a new app shows “Toon Bijwerken (1)” as expected
Best is to do 1 action at a time, so first remove and then install or other way around.
Doerakker
Post by Doerakker »
Understand the suggestion.
But that does not address the net counter issue. But then again “it is what it is”
reason for the net counter is that we do not want to install more than 3 apps net at a time. This is because installing too many apps on a Toon 1 can make it unresponsive or make it continuously restarting the gui caused by not enough available memory.
