After recovering my toon i upgraded tot 5.33.9 and it works again.
but the toon store stays empty 0 apps available.
When i run the following command:
curl "https://raw.githubusercontent.com/ToonS ... onRepo.xml"
I get this error. wich i guess is causing the problem,
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
When i run with the -k i get the list.
Allready tried the update script -f and this says the following:
./update-rooted.sh -f
Version: 4.34 - TheHogNL & TerrorSource & yjb - 02-01-2021
If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
Only fixing files.
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.33.9.
EDITING: disabling Eneco subscription feature apps to free up memory on this toon 1
EDITING: disabling samba nmbd on toon 1 as probably it is not necessary
There is a new version of the Mozilla CA pem file. Downloading it!
Finished fixing files!
tried a reboot with goot hopes, but still no apps available.
empty toonstore, certificate error
Re: empty toonstore, certificate error
The line:
Should be followed by:
Download ok! Replacing Mozilla CA pem file!
So something is not workign while updating the CA pem file.
It is this part of the update script. Can you check from this script lines where it goes wrong? maybe the curl download?
echo "There is a new version of the Mozilla CA pem file. Downloading it!"
/usr/bin/curl -Nks https://curl.haxx.se/ca/cacert.pem -o /tmp/mozilla.crt
SHA256NEW=`/usr/bin/sha256sum /tmp/mozilla.crt | cut -d\ -f1`
if [ "$SHA256ONLINE" == "$SHA256NEW" ]
then
echo "Download ok! Replacing Mozilla CA pem file!"
mv -f /tmp/mozilla.crt /usr/local/share/ca-certificates/mozilla.crt
UPDATECA=true
fi
I’m having the same issue on 2 different toons.
this is the concent of the mozilla cert file:
Thats not good...
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>301 Moved Permanently</title>
</head><body>
<h1>Moved Permanently</h1>
<p>The document has moved <a href="https://curl.se/ca/cacert.pem">here</a>.</p>
<hr>
<address>Apache Server at curl.haxx.se Port 80</address>
</body></html>
Thats not good...
<html><head>
</head><body>
<hr>
</body></html>
I see. I need to change the script. I will do that nowPeter1612 wrote:this is the concent of the mozilla cert file:
Thats not good...
<html><head>
</head><body>
<hr>
</body></html>
i redownloaden the update script from: https://github.com/ToonSoftwareCollective/update-rooted
did and update -f again and it seems to be working now.
maybe had an old or wrong update script i guess.
thanks for your help!
No I just updated the scriptPeter1612 wrote:i redownloaden the update script from: https://github.com/ToonSoftwareCollective/update-rooted
