i thinking of camera intagration in my home automation system.
what hardware to use ?, my set up is an HS2 system with the intagration of plugwise, x10,rfxcom,onewire, what surgestions can u guys give me.
camera intagration
Moderator: Esteban
Re: camera intagration
Easiest? Use a foscam. Or better mobotix. Lots of info to be found on the foscam. Use the Stream URLs in combination with the netcam plugin.
Verstuurd vanaf mijn Nexus 5 met Tapatalk
groeten,
I`m using Dlink camera`s and have used Linksys in the past. They are affordable. Mobotix is high level just like axis and quite high priced. I`m using the NetCam plugin
