Refresh/update time on 1-wire network
Forum about 1-Wire devices.
Postby the__creature » Sun Jan 03, 2016 6:16 pm
What response time can one expect on a 1-wire network that consist of around 20 different sensor - miliseconds, seconds?
Are trying to find out if one can use magnetic sensor on the doors connected to 1-wire to turn the on light
Thanks
the__creature
Re: Refresh/update time on 1-wire network
Postby KMTronic » Tue Dec 15, 2020 1:27 pm
I in a hurry test read Scratchpad one DS18B20 1-wire sensor 20 times.
Here is code:
for ( int a = 0; a < 19; a++) {
          present = ds.reset();
          ds.select(addr);
          ds.write(0xBE);         // Read Scratchpad
          for ( i = 0; i < 9; i++) {           // we need 9 bytes
            data[i] = ds.read();
            Serial.print(data[i], HEX);
            Serial.print(" ");
          Serial.println();
Serial.println("----------------------------");
SerialMonitor show:
13:02:24.882 -> ----------------------------
13:02:24.882 -> 50 5 4B 46 7F FF C 10 1C
13:02:24.916 -> 50 5 4B 46 7F FF C 10 1C
13:02:24.950 -> 50 5 4B 46 7F FF C 10 1C
13:02:24.984 -> 50 5 4B 46 7F FF C 10 1C
13:02:25.018 -> 50 5 4B 46 7F FF C 10 1C
13:02:25.052 -> 50 5 4B 46 7F FF C 10 1C
13:02:25.086 -> 50 5 4B 46 7F FF C 10 1C
13:02:25.119 -> ----------------------------
So for reading 20 sensors you need approximately 200-250 ms.
Regards
KMtronic
KMTronic
Return to 1-Wire Forum
