Hi there,
i tried to create an 1-wire temprature sensor using the following scheme:
and now i tried it using LogTemp (http://www.mrsoft.fi/ohj01en.htm)
but it keeps telling me: "1-Wire network does not exist"
how can i troubleshoot this?
[Edit 19-05-2012 23:52]
after some testing and searching i got it working with this scheme:
With Regards,
home made 1-wire temp sensor won't work
- Starting Member
- Starting Member
Re: home made 1-wire temp sensor won't work
You can use this circuit as 1 Wire to RS232 Interface.
I can provide you the PCB files if you plan to make your own..
- Schematic - RS232 1Wire Hub
- 1W-DSensor-RS232DS-V1-schematic.jpg (26.28 KiB) Viewed 9731 times
is it possible to connect the 1-wire devices from hobby-boards.com to the RFXsensor and use the value in HS?
raza
