I use a temperature sensor 1-wire, and a switch to turn the DS2408 gas heating. Everything works fine, you can manually turn on the device. I configured the thermostat and, unfortunately, does not want to change the status PIO.0 to '1 '. Manually running, I can turn on / off, I use owfs to support 1-wire.
Annex configuration, hand temperature and greater expected thermostat can see he knows but does not change the state of 1-wire switch.
The problem with Thermostat and switch 2408
- Screen Shot 2012-09-24 at 15.31.38.png (12.22 KiB) Viewed 5443 times
- Screen Shot 2012-09-24 at 15.31.07.png (18.2 KiB) Viewed 5443 times
- Screen Shot 2012-09-24 at 15.30.18.png (27.24 KiB) Viewed 5443 times
