Migrate RFXcom device database from HS2 to HS3
raymonvdm
Post by raymonvdm »
I`m in the process of migrating my home from HomeSeer2 to HomeSeer3 but is there a way to migrate all RFXcom devices from HS2 to HS3 (in an easy way) so i can keep the device id`s which are used to send to my KaKu plugs (so i don`t have to relearn all modules)
b_weijenberg
Re: Migrate RFXcom device database from HS2 to HS3
Post by b_weijenberg »
See the attached pdf
Export RFXCOM HS2 to HS3.pdf
(56.16 KiB) Downloaded 657 times
raymonvdm
Post by raymonvdm »
It seems to be working, but my interface is not yet working in HS3 it keeps hanging on
26 (DeviceCmd) transceiver #1 State:Initializing Command not transmitted!
But after update to 30.0.0.28 the interface now seems to be working :D
Wim2008
Post by Wim2008 »
Where stands the database of HS3? It's for making a backup.
Wim
b_weijenberg
C:\Program Files (x86)\HomeSeer HS3\Data
Wim2008
Post by Wim2008 »
En de file heet dan waarschijnlijk 'HomeseerData_7_3.hsd'.
Maar er staan 3 files met een ander getal op het laatst van dezelfde datum. Wordt de database dan opgebouwd in 3 files?
Wim
Wim2008
Post by Wim2008 »
I bring all the device in by hand in HS3. By RFXcom devices I can make a lot of choices.
Now I looking for the MS13E. In HS2 it was a a MS13A (Hawkeye II) type.
How must I bring this device in HS3? And which sort of device is it?
B.R. Wim
b_weijenberg
There is an import utility for RFXCOM devices from HS2 to HS3.
An MS13 is a X10 device and must be added by hand on the Homeseer main page.
Select STATUS ONLY for the house code used by the MS13 on the RFXCOM General config page.
Wim2008
Post by Wim2008 »
Thanks Bert. I will try your information later this week for the MS13A device.
I have tried the import utility, but I like to bring in the devices by hand. So I can use the code I like.
B.R. Wim
Wim2008
Post by Wim2008 »
In the main page of HS3: I was going to the plug-ins. In this pulldown menu I made the choice of RFXcom and in the second pulldown menu Output devices.
Here I made a X10-module for the MS13A. See attachment. I hope this will work.
Wim2008
Post by Wim2008 »
Which RFXCOM output device type must I choose for a Sun-650 in HS3?
Wim
