BTHGN129
Moderator: b_weijenberg
Herbus
BTHGN129
Post by Herbus »
I added the BTHGN129 to my config. RFXLan gives the following failure continues in the HS3 log:
jan-24 16:07:35 RFXCOM 29 (CheckReceivers) receiver #1 info: resynced
jan-24 16:07:35 RFXCOM Error: 29 (RecRxChar) error :System.InvalidCastException: Conversion from string "BaroForecast.NoInfo" to type 'Byte' is not valid. ---> System.FormatException: Input string was not in a correct format. at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat) at Microsoft.VisualBasic.CompilerServices.Conversions.ToByte(String Value) --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.Conversions.ToByte(String Value) at HSPI_RFXCOM.Oregon.processoregon() at HSPI_RFXCOM.receiver.RecRxChar(Byte bytComChar, Int32 irec)
Based on this list I assumed that it could work with an RFXLan: http://www.rfxcom.com/epages/78165469.s ... ies/oregon
The device doesn't show up in the Input Devices screen.
What's going wrong?
Herbus (Jos)
b_weijenberg
Re: BTHGN129
Post by b_weijenberg »
This problem is produced by the BTHGN129 which you have in use.
I have sent you an updated plugin.
Herbus
Re: BTHGN129
Post by Herbus »
Thanks Bert, I will install the update and report the result.
Herbus (Jos)
Herbus
Re: BTHGN129
Post by Herbus »
The update solved the problem. Thanks Bert!
Herbus (Jos)
scottymoen
Re: BTHGN129
Post by scottymoen »
Dear,
i'm using the BTHGN129-sensor now for a few days.
Temp and humidity are OK, but there is no forecast displayed in Domoticz.
I also have the impression that the value from the baro is not correct (1010 but on sensors give my 1030 hPa)
Hardware: Rfxcom - Rfxtrx433 USB 433,92 Mhz with a Raspi 3
Sofware: Domoticz
Thanks for your reply!
Grtz
Bjorn
