modify xpl-rrd result put in textfile
Postby Kroonen » Sat Mar 01, 2008 8:49 pm
I'm using xpl-frxcom, and xpl-rrd to create graphs.
xpl creates nice de rrd file in the /var/lib/rrd/sensor
It should be nice to modify the script to put also in the directory a text file with tha values he uses, to the temp, humidity of that sensor.
So that I can import the file with the values in an own database.
Any idea how to acomplish this????
Kroonen
Postby Snelvuur » Sun Mar 02, 2008 12:33 am
you can read out the values from the rrd files, then you can export them yourself. depending on what you need, zenah offers a normal interaction with the database (it only saves values of the devices you want to keep) making graphs with mysql/php/cgi easier. I would like to see zenah be userfriendly and more options, when that is the case its easier to work with and will make followers too.
Snelvuur
Return to Linux Forum
cron
