Switching devices, which one?
Moderator: TANE
nelis13
Post by nelis13 »
Ok sorry in English,
I'm new to Domotica and I started yesterday with Duwi switches, but they dont fit well en feel cheap. So back to the drawing board:
* I'd like to put in Fibaro Relay Insert 2 * 1.5 KW behind the existing buttons in my home (so the touch and feel remains the same.)
Questions about this item:
* is it so that I can couple two switches to one module as it is 2x1,5kw?
* And can I use it to integrate it in an existing Hotel-switch setup (just in one side of the hotel switches? ) As it can turn 2 switches (When I couple the switch to S1 and S2 (at the same time) and the O1 en O2 to the different 2 schakeldraden in the hotelsetup?)(will it close both O1 and O2 when I turn the switch?)
Now I need to put in a Fibaro dimmer in an existing round turning button. That will not work! So I need to change the contact.
* what kind of Drukcontact will I need? wissel / maak drukcontact? with or without nulklem? Also a noob when it comes to electrical stuff (uhoh)
As I said I'm just starting. But I want it to be and look good.
Return to “Domotica for Dummies Forum”
