MS MCE Blaster
Moderator: RDNZL
MS MCE Blaster
I saw reference to a Microsoft MCE receiver being able to be used in Domotiga. Is it possible to use it as a blaster? That would be awesome, as I have one, they are freely available, and much cheaper than something like a GC-100.
Re: MS MCE Blaster
I am not familiar with DomotiGa, and I don't know if the ehome reciever can communicate directly with it.
but..
I was looking for a simular solution for Homeseer, since I also have several ehome receivers and blasters laying arround.
I found that I can send IR commands using the IR blasters trough LM remote Keymap from LMGestion.
The Donaters version has a REST API.
Via this API it is possible to execute commands within LMRemote by sending Get URL commands to the machine where LM remote is running on.
Bottom line, when your domotica software is able to send Get URL commands you can use LM Remote Keymap to do what you want.
You will need a Windows box running 24/7 since LMRemote is a Windows app.
This is no problem for me since Homeseer is a Windows application also, but can be a little bit of a problem if your only 24/7 box is a linux machine.
greetzz
Martijn.
but..
greetzz
Martijn.
- RDNZL
Re: MS MCE Blaster
The current LIRC interface only supports receiving of IR codes.
Adding the ability to send IR codes it not so hard I think, so if lirc supports using the MCE as a blaster, it's doable.
Will add it to the list.
If someone else have some free time to look at it, would be great!
Regards, Ron.
Re: MS MCE Blaster
It is possible to blast in Linux, I used to do it in MythTV. I think this explains the library they use: http://www.mythtv.org/wiki/MCE_Remote
Would be pretty cool to have that to switch sources on TV's, amps, and STB's.
