I've installed DomotiGa server onto my OpenRD arm system and I'm happy with the results although it streaches the resources available on the system. This could explain why it stopps running from time to time for no aparent reason. When it stops then the device datas stop ebing logged so I have come up with this simple solution after having problems with the init.d daemon I wanted to use. The script will re-run itself when the server stops. It's been in use for a few days now and the logs are complete now since its been in use so I'm sticking with it just like it is.
#keepalive.domotiga
/home/david/domotiga/DomotiGaServer.gambas
/home/david/domotiga/keepalive.domotiga
hth DAvid.
