Opentherm gateway
Moderator: RDNZL
vossie
Opentherm gateway
Post by vossie »
Hi there.
I have problems updating my opentherm outside temp using the temperature of my weatherstation.
I made an action script Devices.ValueUpdate(121, Dev_38_Value, "", "", "") but the action is not updating my oudside device
When i test the script on a dummy device its working ok.
Also when i update the ouside device directly the command is send and the device is updated.
i did this in the event action editor on the tab "Set Device"
any one of u guys know whats going on?
BreFra
Re: Opentherm gateway
Post by BreFra »
I took a look inside the sourcecode and there is indeed a difference beween the two commands. The "ValueUpdate" doesn't send the command to the Opentherm gateway. So to get it working use this script
Devices.SetDevice("<name of opentherm outside temperature device>",Dev_38_Value )
vossie
Post by vossie »
Thanks, its working.
Return to “DomotiGa Forum”
