No drivers in linux kernel
Moderator: RDNZL
Postby ronaldkelleners » Tue Sep 09, 2014 10:11 am
Hi there,
I am trying to use a radxa rock as domotiga server, problem:
Ubuntu--> something strange with php installation / apache .. not getting it working correctly within the domotiyii interface.
Debian, domotiga running fine, web interface running fine, except there are no drivers to support the uart of the Zwave stick S2, and the ftdi chipset of the rfxcom reciever ...
Anyone tips ?
Kernel version 3.0.36, in kernel 3.2 all the drivers are instaled, is there a way to boot tis kernel or copy the drivers ?
thank Ronald
ronaldkelleners
Re: No drivers in linux kernel
Postby emvee » Tue Sep 09, 2014 6:51 pm
A bit too less information to say anything useful (at least for me).
Questions:
emvee
Postby jeroen_ » Sat Sep 20, 2014 5:14 pm
ronaldkelleners wrote:Kernel version 3.0.36, in kernel 3.2 all the drivers are instaled, is there a way to boot tis kernel or copy the drivers ?
You cannot just copy over drivers like in Windows, this as Linux does not have a driver model like windows, hence they are required to be compiled against the same version, this to make sure that they end up in the kernel tree as source instead of being able to keep them separate.
As you mentioned Ubuntu, check with:
dpkg --list| grep linux
which kernels are currently installed. The upgrade process should take care of informing grub that there is a a new kernel (by updating /boot/grub/grub.cfg). You'll need to reboot to get it though.
You can check which ones are there with:
cat /boot/grub/grub.cfg  |grep menuentry
or just reboot, which should get you a menu ;)
jeroen_
Postby thomas7 » Wed Nov 12, 2014 7:05 pm
i am using MK902 (Cortex A9 RK3188 1,8 GHz) with linuxium.
I had to build the driver for the Aeon Stick by myself but it is very easy.
Kernel: 3.0.36+
Sources are open, just download the kernel sources, symlink it to /lib/modules/3.0.36/build
then you can download the Aeon Lab Sources from their page and just make the cp210x.ko module ;)
Hope this helps you.
thomas7
Postby emvee » Wed Nov 12, 2014 11:06 pm
@thomas7:
Thanks for these instructions!
I have added based on it some text on https://www.domotiga.nl/projects/domoti ... s_Stick_S2 but things are not 100% clear to me:
Where do you have to do this?
how to do that exactly.
Feel free to update the Wiki if you want.
emvee
Postby thomas7 » Thu Nov 13, 2014 8:46 am
ok so first you need your Linux Source.
The Sources depends on the exact Device and of course the Image you use.
Here is an example with an MK902 and (almost same as MK802IV and some others) with Ubuntu 12.04 (Kernel 3.0.36+) called Linuxium.
So for me i had to download the sources here: https://github.com/linuxium/3188-SRC-AP6210
Unzip the sources.
As sources are still in your homefolder, but you need it at /lib/modules/3.0.36+ we do not copy it, we hast link it.
maybe create build folder if not exist then
sudo ln -s /home/linuxium/install/kernel /lib/modules/3.0.36+/build
Now we have a "pointer" from the sources to the build directory.
Remember, you need your own linux sources for your image/device.
Now download here http://aeotec.com/z-wave-usb-stick/1358 ... ivers.html
The Driver for Linux 3.x.x
Unzip ist
Enter the directory Linux_3.x.x_VCP_Driver_Source
just type in:
make
This should be all, your cp210x.ko will be build in some seconds.
Test the new module:
sudo insmod cp210x.ko
Check with dmesg if you have now created ttyUSB0
Autostart it:
Copy the cp210x.ko to /lib/modules/3.0.36+/kernel/drivers/usb/serial/cp210x.ko
enter sudo depmod
Now you are finished, enjoy it ;)
I hope that was OK, if not i can try my best to explain better. And sorry for my bad englisch, it is not my mother-language.
thomas7
Postby sirkhoi » Fri Feb 27, 2015 8:09 pm
I am a newbie in the world of home automation. Right now I am using RAspberry Pi B+, freshly installed with Raspbian Debian Wheezy. I have problem installing the driver for Aeon Z-Stick S2, but I didn't succeed so far.
I have downloaded the Linux 3.x.x VCP driver, unzip it and run make command, but it didnt work. The error was there is no "build" directory in /lib/modules/3.18.7+/build
If I tried to create a build there, then run make again then another error: no rule to make target modules,
In the previous posts, I saw you guys have to download the source first, then have a pointer to the build directory. I dont know what is the source in my case.
Thank you very much, please help me since it is part of my thesis work for graduation.
Many thanks
sirkhoi
Postby jeroen_ » Sat Feb 28, 2015 1:43 am
According to:
http://lxr.free-electrons.com/source/dr ... x.c?v=3.18
that cp210x driver is already in the kernel tree since 3.3, thus likely you do not need to do this.
It is likely a module though, hence you'll need to load it.
On my box:
root@raspberry:~# find /lib/modules/ -name "cp210x*"
/lib/modules/3.12.26+/kernel/drivers/usb/serial/cp210x.ko
/lib/modules/3.18.7-v7+/kernel/drivers/usb/serial/cp210x.ko
/lib/modules/3.18.7+/kernel/drivers/usb/serial/cp210x.ko
Hence, just try loading that.
See also:
which states:
"The stick works out-of-the-box on Raspbian, Cubian, Ubuntu and many other Debian based distributions. "
otherwise....
sirkhoi wrote:Hi all,
You need to install the relevant kernel package for building new modules. Either linux-source-3.18 or linux-headers-3.18.xxx; do a 'apt-cache search | grep linux-source' or 'apt-cache search | grep linux-headers' to figure out which packages you likely need. You likely also want to install linux-kbuild-3.18 (or depending on the version you have).
Creating a directory does not create all the actual files, like the Makefile that contains the instructions. You'll need to install the packages, see above.
jeroen_
Return to DomotiGa Forum
