adding plugwise stretch to source
Postby labium » Sun Oct 23, 2016 11:12 am
i bought a plugwise stretch on marktplaats without any modules, i wanted to add it to my source but the source says unknown stretch id and breaks the adding. i can see the stretch on my network and http it. is it posseble to let the stretch use the circle + of the source without sending it to plugwise ?
labium
Re: adding plugwise stretch to source
Postby Akatar » Sun Oct 23, 2016 3:04 pm
can you add the stretch to the plugwise app?
you need the circle+ that came with the stretch
Akatar
Postby PietjeNL » Mon Oct 24, 2016 12:15 pm
Stretch and Source doesn't work together.
Smile will work in Source.
PietjeNL
Postby labium » Mon Oct 24, 2016 8:14 pm
i bought a stretch without circle + but if i cant add the stretch to my source network i will put it on marktplaats again. or can use the same circle plus with source and stretch
labium
Postby RdP » Tue Oct 25, 2016 12:31 pm
labium wrote:i bought a stretch without circle + but if i cant add the stretch to my source network i will put it on marktplaats again. or can use the same circle plus with source and stretch
The Stretch has it's own Plugwise Stick inside of the box and needs a Circle+ to operate and create the Plugwise network. If you don't have the Circle+ which was configured with the Stick of the Stretch you won't be able to use the Stretch or add additional Plugwise devices.
The Stretch is an alternative for the Source and they don't work together!!
RdP
Return to Plugwise Forum
