Not licensed for extended scripting
Re: Not licensed for extended scripting
Postby jvmkite » Tue Feb 14, 2012 12:11 pm
Thank you very much Darwusch, the patch works fine.
Greetings from Portugal - José... :-)
jvmkite
Postby jjdoom » Sat Mar 17, 2012 4:59 pm
With the new version it doesn't work for me anymore. Try to find the same hex but when i change it it still won't start.
Did anyone already got it to work on 2.22 ?
jjdoom
Postby taydin » Thu Jun 14, 2012 9:31 am
thanks Darwuch, i have followed step by step and change the value from 06 to 17 but i cannot save it. It gives error, is there also a way to surpass it?
taydin
Postby Darwusch » Fri Jul 13, 2012 10:14 pm
Close plugwise before you save the file. Then run pluwise again.
Darwusch
Postby DekkerAldo » Sun Jul 22, 2012 2:55 pm
Darwusch,
I have used your solution for some time, but I just got a new update on 20-07-2012 New assembly version 2.20.4565.24024 Plugwise.Images.dll (still file version 2.20.0.0).
I have been searching for the same sequence of bytes, but cannot find it in this file. How did you find the byte to be changed? I have tried to disassemble the file but I do not understand much of the assembly language.
Aldo Dekker
DekkerAldo
Postby Darwusch » Mon Jul 23, 2012 5:17 pm
DekkerAldo wrote:New assembly version 2.20.4565.24024 Plugwise.Images.dll (still file version 2.20.0.0).
For this version it is hex-address 20D9.
Same change: 06 -> 17
To learn assembly, there are many other good forums on the internet.
Darwusch
Postby DekkerAldo » Mon Jul 23, 2012 7:45 pm
Darwusch,
Thank you for the quick answer. I changed the byte to 17. But still get when I open http://localhost:8080/ the message: Note: The totals are 0, because Extended Scripting is disabled.
I made my own script to copy the production data from my PV panels. This is also not working. So the solution is not the same as in the previous assembly versions of Plugwise.Images.dll
Aldo
DekkerAldo
Postby Darwusch » Mon Jul 23, 2012 9:57 pm
You have to edit the web page too, just search in the web files for that sentence :-)
Files appliancestable.pte and appliancetypestable.pte (scripts use these files).
Look for the if statements with
ContainsValue('E')
Darwusch
Postby DekkerAldo » Thu Jul 26, 2012 1:51 pm
Darwusch,
Thanks for your efforts but it did not work, I thought. So I ordered the update.
Now I saw that my script was also outdated, because the scripting language has changed also in the new version. They added new features and old features were not working anymore. E.g. I looked for .log(date)[1][0], but this has changed to .log[0][4]. If I would have used names instead of the numbers it would probably have stayed the same.
I could have saved € 19.95. But the time I have spend in searching for a solution made buying the additional licence worth paying for.
To check whether the additional licence works I have added
<% echo 'Plugwise FeatureFlags ', Plugwise.FeatureFlags %>
To my webpage I use for seeing the production data of my solar panels for the last month. And before the updated licence I saw.
Plugwise FeatureFlags { 'W' }
Now I get:
Plugwise FeatureFlags { 'W', 'X', 'E' }
So no need to delete the statements ContainsValue('E') from both the .pte files.
But thank again you have been a big help in the past before I paid for the extended scripting. I saw the value of the scripting and was able to test the system.
Aldo
DekkerAldo
Postby Darwusch » Thu Jul 26, 2012 7:48 pm
Hi Aldo,
I'm glad you got it working. You're right, the time is worth the money.
Darwusch
Darwusch
Postby erikk » Thu Aug 02, 2012 7:35 pm
Do the Pro-features actually work for you with this hex-editting? I can select usage per 5 minutes in the report section now, but it isn't showing any data at all. When I switch back to usage per hour it works again. Do I have to restart the circles or something? I've already waited an hour, but doesn't change anything. Exporting a CSV does work though.
Edit: I reset my stick, reset my circle+ and reset my circle now and reset the source-application by removing the userdata-folder. Going to see if usage per 5 minutes works now...
erikk
Postby Darwusch » Thu Aug 02, 2012 10:00 pm
I have only activated extended scripting. The 5 min interval does not work with it.
Darwusch
Postby erikk » Fri Aug 03, 2012 4:00 pm
Ah okay. Yeah, 5 minute interval still doesn't work after resetting etc. :) Funny that it does show in the GUI though. Plugwise support says a Pro license costs 200 euros. That's a bit much for smaller intervals imo. Too bad. Might sell my plugwise and get an arduino + s0-kwh-meter or something.
erikk
Postby Dowser » Tue Sep 04, 2012 6:27 pm
Koen Zomers wrote:Sending your Plugwise Source license key to helpdesk@plugwise.com requesting your license to be upgraded to include the script extensions will have them upgrade your license for free.
Nope, I got the answer "The extended scripting option is a payed license option and will cost arround 999 euro's." :(
I'll think I will pass...
//Markus
Dowser
Postby vanisher » Tue Sep 04, 2012 8:25 pm
It was about € 19,95
A Domotica starter, currently running: Plugwise, Z-Wave, Jeenods, Homeseer / DomotiGa
vanisher
PreviousNext
Return to Plugwise Forum
cron
