Hi !
MarnixT wrote:you're picture of domoticz in an ELV max topic got me triggered. As I just found out Dmitry also provided HTTP automation with the client which allows for integration with Domoticz (e.g. using node-red and/or MQTT).
You did not yet try to run the programs on the PI itself, did you?
when I find the time I would like to start experimenting as well.
Thanks for answering... Actually i did not try to install the fine program, which dmitry wrote on my Pi!; as i wrote i installed it without problems on my ubuntu laptop, with the "wine" windows emulator. I did not try to install the Linux native, as i found it much easier to just grap the windows package.
If you look, at button of this reply, you see a picture of a perfect working application
-I did not try the http stuff yet through, but i am sure it will work.
Anyway, i am looking for a simple way to proceed a command to adjust the valves.
I tried to make som curl/telnet calls, but i cant figure out, what to write, and how.
Here is a pastout of a curl call :
- Code: Select all
jesper@JesperHP:~$ curl http://192.168.1.127:62910
H:LEQ1325887,115473,0113,00000000,74496c4d,04,32,100112,122e,02,0001
M:00,01,VgIEAQxTb3ZldsOmcmVsc2URSHYCEkpvc2VmaW5lcyB2w6ZyZWxzZRFH6gMSRnJlZGVyaWtzIHbDpnJlbHNlEUgCBARTdHVlEUdJBQUBuHtKRVEwMzA2NjM5DEVjbyBTd2l0Y2ggMQACEUh2TEVRMTMzMDUxMgxTb3ZldsOmcmVsc2UBAhFHSUxFUTEzMzAyMTUEU3R1ZQQCEUfqTEVRMTMzMDM3NhNKb3NlZmluZSdzIHbDpnJlbHNlAgIRSAJMRVExMzMwNDAwE0ZyZWRlcmlrJ3MgdsOmcmVsc2UDAQ==
C:115473,7RFUcwATAf9MRVExMzI1ODg3AQsABEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAsABEAAAAAAAAAAQQAAAAAAAAAAAAAAAAAAAAAAAAAAAGh0dHA6Ly9tYXguZXEtMy5kZTo4MC9jdWJlADAvbG9va3VwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENFVAAACgADAAAOEENFU1QAAwACAAAcIA==
C:114749,0hFHSQIEEABMRVExMzMwMjE1KiI9CQcYAzAM/wBESFMaRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIUw5FIEUgRSBFIEUgRSBFIEUgRSBFIEUgRD9MbESoUxRFIEUgRSBFIEUgRSBFIEUgRSBEP0xsRKhTFEUgRSBFIEUgRSBFIEUgRSBFIEQ/TGxEqFMURSBFIEUgRSBFIEUgRSBFIEUgRD9MbESoUxRFIEUgRSBFIEUgRSBFIEUgRSBEP0xsRKhTFEUgRSBFIEUgRSBFIEUgRSBFIA==
C:114802,0hFIAgIDEP9MRVExMzMwNDAwKiI9CQcYAzAM/wBESFUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIVQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhUbESoVQVFIEUgRSBFIEUgRSBFIEUgRSBESFRsRKhVBUUgRSBFIEUgRSBFIEUgRSBFIERIVGxEqFUFRSBFIEUgRSBFIEUgRSBFIEUgREhUbESoVQVFIEUgRSBFIEUgRSBFIEUgRSBESFRsRKhVFEUgRSBFIEUgRSBFIEUgRSBFIA==
C:01b87b,EQG4ewUAEg9KRVEwMzA2NjM5
C:114876,0hFIdgIBEP9MRVExMzMwNTEyKiI9CQMYAzAM/wBESERtRHhU/0UgRSBFIEUgRSBFIEUgRSBFIERIRG1EeFT8RSBFIEUgRSBFIEUgRSBFIEUgRD9EbkS1VP5FIEUgRSBFIEUgRSBFIEUgRSBEP0RtRLRU/kUgRSBFIEUgRSBFIEUgRSBFIEQ/RG1EtFT+RSBFIEUgRSBFIEUgRSBFIEUgRD9EbUS0VP5FIEUgRSBFIEUgRSBFIEUgRSBESERtRKhU/EUgRSBFIEUgRSBFIEUgRSBFIA==
C:1147ea,0hFH6gICEP9MRVExMzMwMzc2KiI9CQUYAzAM/wBESFUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIVQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhUbESoVQVFIEUgRSBFIEUgRSBFIEUgRSBESFRsRKhVBUUgRSBFIEUgRSBFIEUgRSBFIERIVGxEqFUFRSBFIEUgRSBFIEUgRSBFIEUgREhUbESoVQVFIEUgRSBFIEUgRSBFIEUgRSBESFRsRKhVFEUgRSBFIEUgRSBFIEUgRSBFIA==
L:CxFHSQkSGA8qAAAACxFIAgkSGAAqAAAABgG4ewkSEAsRSHYJEhgKKgDhAAsRR+oJEhgQKgAAAA==
I don't know howto make executing commands and soo on, and what to write.... I tried different but it dont seems to work!
All i actually need is to set the valves (4pcs), so that i can control the heating with my presence detection... controlling ecoswitch and windowssensor etc... would ofcause just be a nice bonus!
I see, that it might be possible to install another server at my pi, and maybee control it with that? -But i really prefer if possible to have it simple.
So once again i kindly ask, if someone here knows a simple way of archiving that ?
Rgds; Jesper.
