Page 4 of 12
Re: ELV MAX! protocol description
Posted: Wed Oct 31, 2012 10:11 am
by Kingsammy
Update for H-Response:
H:IEQ0123456,00b3b4,0102,00000000,355df98a,03,32,0c0a1f,0837,03,0000
IEQ0123456 Serial number
00b3b4 RF address, hexadecimal
0102 Firmware version: 258, Other values 010e = 270, Other values 010e = version 270,
0111 = version 273
00000000 ?
355df98a Connection IP
03 Duty cycle in %. 03 (hex) means 3(dec) %. Other collected values after
sending some commands to cube: 1a = 26(dec) in %, 1d(hex) = 29(dec) %, 2a = 42(dec) %
32 ?
0c0a1f Systemdate: 0C = Year (Year 2000), 0A = Month, 1F = Day --> 2012.10.31
0837 Systemtime: 08(hex) = 8 hours, 37(hex) = 55 minutes --> 08:55
03 ? Could be the HW-Revision of Cube
0000 ?
Posted: Thu Nov 08, 2012 12:11 am
by dasdandre
Thanks for sharing all the information. If it's not allready known.
I've figured out some (more) bytes of the M-Response (the decoded part).
This is my interpretation:
first 2 bytes: Unknown(maybe METADATA-VERSION)
next 1 byte: number of rooms
followed by number of rooms times:
next 1 byte: roomID
next 1 byte: length of roomname
next (length of roomname) bytes: roomname
next 3 bytes: rf-adress of first room device (some kind of useless)
followed by:
next 1 byte: number of devices
followed by number of devices times:
next 1 byte: deviceType (1:thermostat,4:window-contact,5:eco-switch)
next 3 bytes: rf-adress of device
next 10 bytes: serial
next 1 byte: length of devicename
next (length of devicename) bytes: devicename
next 2 byte: roomid
Posted: Thu Nov 08, 2012 3:02 pm
by Kingsammy
Can you please post your M-response Data base64-coded and the hex-values which you have used in your example?
Posted: Fri Nov 09, 2012 4:11 pm
by dasdandre
Here is my m-response:
M:00,01,VgICAQpXb2huemltbWVyAh1mAgpCYWRlemltbWVyAg+dBgQCXFdKRVEwMTYyMTkzEEZlbnN0ZXJrb250YWt0IDEBAQIdZkpFUTAyNTU4OTQSVGhlcm1vc3RhdCBFc3NlY2tlAQECGLlKRVEwMjU1ODc1FFRoZXJtb3N0YXQgenUgS8O8Y2hlAQUCR7BKRVEwMjEzNTk2CkVjbyBTd2l0Y2gABAJeQkpFUTAxNjI2NzEQRmVuc3RlcmtvbnRha3QgMQIBAg+dSkVRMDI1MTY0Ng5UaGVybW9zdGF0IEJhZAIB
and the decoded hex-values:
(codeview seems to trim leading blanks, i replaced it by an underscore)
V....Wohnzimmer. | 56 02 02 01 0a 57 6f 68 6e 7a 69 6d 6d 65 72 02
.f..Badezimmer.. | 1d 66 02 0a 42 61 64 65 7a 69 6d 6d 65 72 02 0f
....\WJEQ0162193 | 9d 06 04 02 5c 57 4a 45 51 30 31 36 32 31 39 33
.Fensterkontakt | 10 46 65 6e 73 74 65 72 6b 6f 6e 74 61 6b 74 20
1....fJEQ0255894 | 31 01 01 02 1d 66 4a 45 51 30 32 35 35 38 39 34
.Thermostat Esse | 12 54 68 65 72 6d 6f 73 74 61 74 20 45 73 73 65
cke.....JEQ02558 | 63 6b 65 01 01 02 18 b9 4a 45 51 30 32 35 35 38
75.Thermostat zu | 37 35 14 54 68 65 72 6d 6f 73 74 61 74 20 7a 75
_K..che...G.JEQ0 | 20 4b c3 bc 63 68 65 01 05 02 47 b0 4a 45 51 30 (first char is blank)
213596.Eco Switc | 32 31 33 35 39 36 0a 45 63 6f 20 53 77 69 74 63
h...^BJEQ0162671 | 68 00 04 02 5e 42 4a 45 51 30 31 36 32 36 37 31
1.....JEQ0251646 | 31 02 01 02 0f 9d 4a 45 51 30 32 35 31 36 34 36
.Thermostat Bad. | 0e 54 68 65 72 6d 6f 73 74 61 74 20 42 61 64 02
. | 01
Posted: Fri Nov 09, 2012 6:14 pm
by dasdandre
Some update to the L-response:
L-response of a window-contact is only 6 Bytes long.
bit-2 of byte-6 indicates the window open status.
EDIT:
bit-1 of byte-6 indicates the window open status.
0=closed,1=open
if ((value & (1<<1)) !=0)
console.log("Window open");
Posted: Tue Nov 13, 2012 10:54 am
by Kingsammy
@dasandre
Yes, i can confirm your update on L-Response regarding the shuttercontact.
HEX-Values (Extract from a L-Response for a shuttercontact): 06 00 6a 48 09 12 12
06 Length of following data
00 6a 48 RF-Adress of shuttercontact
09 ???
12 ???
12(hex) 00010010(bin) --> Window open / 10(hex) = 00010000(bin) --> Window closed
Posted: Sun Nov 25, 2012 3:05 pm
by Kawomm
Hi everybody.
Simple question: What is the Connection IP in the H-message? I have no glue which IP address it might be. It's not the ip address of the cube itself, it's not the ip address of the client connecting to the cube. At least as far as I can interprete the H-message replies.
Thanks in advance.
Posted: Sun Nov 25, 2012 8:09 pm
by wwolkers
the H message contains the connection ID, no IP value in there.
Posted: Tue Dec 11, 2012 6:10 pm
by erazor
Hi all.
Thanks a lot for this thread and all the work decoding the protocol.
I started to write a little python library for the communication:
Maybe someone could use it too.
URL is:
svn://erazor-zone.de/e-design/python/pyelvmax
Regards!
Posted: Wed Dec 19, 2012 12:51 pm
by mrecosse
There is a web address in the C response for the cube. On mine this is
http://www.max-portal.elv.de/cube (mine was supplied by ELV). If you open the page it says CubeServlet Executed.
Also in this response is CET and CEST which must be the time zones the cube is set to. Has anyone figured how to change these values through an 's' command? Anyone outside of Central Europe has to set all their schedules in CET
Posted: Mon Jan 14, 2013 12:31 am
by blb
It seems the MAX! Thermostats are sending the actual temperature! I noticed in the MAX!buddy applications this is now implemented and found the protocol information in FHEM; it's in the L: message. I'm update later when I have more time, but I wanted to inform you already about this good News.
Posted: Mon Jan 14, 2013 12:55 am
I assume you mean the room thermostats?
Posted: Mon Jan 14, 2013 11:13 am
by blb
No. I mean the radiator Thermostats! it's combined with the date in the "Date Until", if there is no Date/time until (so when mode =! Mode=10 (Vacation)), the actual temperature is given instead of the Date.
Posted: Mon Jan 14, 2013 12:32 pm
Ok. Do you also know which firmware version introduced this feature?
Posted: Mon Jan 14, 2013 12:39 pm
by blb
I have Radiator Thermostats Firmware version 14, It does work on mine.
