Visonic Powermax Interface (Windows) application
Moderators: Rene, Willem4ever
Re: Visonic Powermax Interface (Windows) application
Postby Mario from Spain » Wed Jun 22, 2016 2:57 pm
bartbakels wrote:it seems that it is triggered fine, however check the errorlog as well. In addition try starting the http commands with http://190...... instead of 190.....
I checked the errorlog but can't find anything related (just many errors like "2016-06-22 15:49:35,318 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi").
Changing http commands to http://192... instead of 192... doesn't make it work neither.
If I change:
192.168.1.145/api/mqtt?topic=visonicdriver&message={"Zone": "9", "Status":"ON"}
to
192.168.1.145/api/mqtt?topic=visonicdriver&message={Zone:9,Status:ON}
IT WORKS
But I need to pass the double quotes.
Mario from Spain
Postby bartbakels » Thu Jun 23, 2016 11:50 am
i expect indeed that the (") cause the issue. I will try to look into this next week.
(ON ESXI )on NUC
bartbakels
Postby Mario from Spain » Thu Jun 23, 2016 2:19 pm
bartbakels wrote:i expect indeed that the (") cause the issue. I will try to look into this next week.
Yes, probably is the '"' that isn't passing well.
Thank you very much.
Mario from Spain
Postby bartbakels » Wed Jul 06, 2016 8:23 am
Mario,
I tried solving the issue, but no luck yet, I just execute a HTTP GET Header request over http, and indeed the payload does not accept "", however i did not find the the solution in the syntax at w3.org, maybe someone have an idea how the payload should look like;
GET /tutorials/other/top-20-mysql-best-practices/ HTTP/1.1
Host: net.tutsplus.com
the first line contaiins the parameters, which thus conatain "" in your case, but these stand for comments normally, cant find the howto let these interpret as string. hope this makes any sense.
Could you try using double quotes;
such as data="test"
data =""test""
or even triple quote
data="""test"""
to test if that works
i will keep you posted
regards
Bart
(ON ESXI )on NUC
bartbakels
Postby wwolkers » Wed Jul 06, 2016 9:45 am
Double quotes are not allowed in a HTTP URL.
The proper encoding would mean using %22 to replace the quotes.
wwolkers
Postby bartbakels » Wed Jul 06, 2016 10:29 am
Mario could you replace the quotes by %22 to test?
(ON ESXI )on NUC
bartbakels
Postby bartbakels » Wed Jul 06, 2016 6:08 pm
released new version;
v1.0.7 Release With Build IN Webserver Installer Location V1.0.7 UPDATED
Changes
- BUG in HTTP GET which prevented Get command with (") and spaces
- Signal strength indicator of sensors available
MARIO please try this build for your HTTP Get Issue
Bart
(ON ESXI )on NUC
bartbakels
Postby Mario from Spain » Fri Jul 08, 2016 6:49 am
Thank you Bart for looking into this.
I will try the new version over the weekend and let you know.
Mario
Mario from Spain
Postby Mario from Spain » Sun Jul 10, 2016 11:55 pm
bartbakels wrote:released new version;
Hi Bart.
There is a issue with the new installer. It doesn't install the exe
Mario from Spain
Postby Mario from Spain » Mon Jul 11, 2016 12:03 am
Well, I'm not sure what the problem is.
When I try to downgrade to v1.0.6 it shows this error:
"System can't find the specified file"
If I try to downgrade to v1.0.5 it doesn't shows an error but there no exe as with v1.0.7
I can try to uninstall the program but, how must I backup my actual config and restore it later?
Thank you.
Mario
Mario from Spain
Postby johnz » Mon Jul 11, 2016 8:26 am
Mario,
Probably better to await Bart's answer, but for both your info:
I had the same issue with 1.07. Uninstalling and reinstalling helped. Make a copy of settings.ini
However, all my user http events were deleted after putting the backup of setting.ini in the settings folder. I ended up copying and pasting these http calls from the backup into the event settings screen.
John
johnz
Postby Mario from Spain » Mon Jul 11, 2016 8:57 am
johnz wrote:Mario,
John
Thank you John.
I managed to restore the 1.0.6 exe file from a backup and looks like it's working now.
Mario from Spain
Postby bartbakels » Mon Jul 11, 2016 9:27 am
gentlemen,
Sorry I think the installer archive is corrupted or incomplete. I will try to create a new one. In my system I just copy the new EXE which is sufficient to upgrade. I am posting only the new Exe which can replace the old one. Please check post no 1.
Regarding backing up, just make a copy of the whole folder. De installer is only needed for the initial installation (Labview runtimes)
But it is strange that your http calls disappeared... never happened to me. But next updates will only be the EXES, to resolve these strange phenomenons
sorry for the inconvenience :oops:
Bart
(ON ESXI )on NUC
bartbakels
Postby Mario from Spain » Wed Jul 27, 2016 8:58 pm
Changes
Bart
Hi Bart.
I'm back from my vacation trip (good things are always very short :( ).
Tried the HTTP GET issue with (") and spaces with the new 1.0.7 version and it's working fine now. Thank you! :D
One of my sensors (zone 20) where not reporting correctly (can see the Open and Close events in the log but Last change was always 00:00:00.000 and didn't call the HTTP URL. I deleted the sensor and recreated it as zone 21 and now it's working fine. I'm not sure if the fault was on my Powermax system or in the Visonic Driver but it looks to me like a bug in the Visonic Driver affecting Zone 20 (don't know for sure if all other zones are working fine as I use just 15 zones out of the 28 my panel permits).
I still get this error very often (I don't thing it's related to previous issue):
2016-07-07 14:19:19,179   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-09 15:20:21,185   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-09 15:36:28,743   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-11 09:53:10,209   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-11 10:01:13,140   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-17 09:36:56,728   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-19 10:08:46,858   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-19 15:53:02,932   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-21 09:57:08,998   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-24 09:40:17,615   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-25 04:08:30,888   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-25 23:12:17,631   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-26 03:40:49,023   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:03:06,990   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:49:39,349   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:49:44,889   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:49:50,285   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:51:43,563   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:52:11,349   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
HTTP GET   TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi
2016-07-27 11:06:46,550   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:06:48,434   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:06:49,572   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:07:18,802   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:10:18,299   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:11:27,691   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:11:45,525   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:12:12,608   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
HTTP GET   TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi
2016-07-27 11:21:44,812   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:22:58,424   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:23:26,228   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:24:54,174   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:25:18,502   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:29:13,624   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:30:20,142   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:30:48,220   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:34:46,448   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:37:33,806   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:40:08,695   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:40:57,669   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:42:41,710   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:44:04,358   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:45:11,436   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:45:39,062   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:03,654   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:09,082   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:14,287   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:19,509   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:24,755   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:29,979   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:35,308   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:40,871   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:46,189   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:51,426   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:56,642   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:02,031   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:07,361   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:12,659   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:17,934   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:23,205   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:28,754   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:34,663   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:40,361   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:44,191   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:47,968   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:49,036   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:50,016   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:51,167   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:56,586   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:02,127   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:07,701   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:13,346   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:19,485   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:24,796   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:30,121   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:35,597   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:40,893   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:46,197   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:51,546   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:56,865   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:02,235   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:07,609   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:12,992   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:18,302   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:23,576   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:27,339   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:30,415   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:35,691   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:40,961   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:44,300   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:45,435   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:46,432   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:47,419   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:48,769   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:49,767   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:50,710   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:51,748   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:52,631   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:38:46,956   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:42:32,473   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:43:00,411   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:44:41,563   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:44:57,206   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:45:32,282   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:45:38,000   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:45:47,855   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:46:01,799   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:46:14,175   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:28:10,211   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:28:15,492   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:28:25,583   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:28:45,736   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:50:00,349   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:50:28,173   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:51:02,513   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:51:08,233   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:51:18,015   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:51:31,945   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:51:45,306   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:53:08,991   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:53:14,274   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:53:39,287   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:55:27,717   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:55:55,594   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:57:50,331   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:58:18,091   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:58:23,411   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:58:33,871   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:58:39,128   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:59:01,419   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:59:37,936   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:00:06,391   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:12:00,252   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:12:27,714   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:17:58,470   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:18:26,333   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:21:50,481   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:22:18,028   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:38:41,633   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:39:09,523   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:40:53,255   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:41:21,095   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:44:03,064   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:44:30,869   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:53:38,818   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:53:54,962   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:54:08,147   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:55:47,334   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:01:38,133   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:02:06,274   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:08:04,734   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:08:34,227   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:08:39,580   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:08:44,871   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:09:09,565   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:09:44,208   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:10:59,545   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:12:02,713   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:40:50,195   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:40:55,477   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:41:18,484   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
Mario from Spain
Postby bartbakels » Thu Jul 28, 2016 7:51 am
Mario,
First the easy part, The error, is an error when the http get call can not be exectuted, probably you have a wrong url in the configurations somewhere, check the http calls you make if they are all correct.
regarding your zones, i have an idea, but is it correct that you now have for example zone 1 until 15 in use and zone 20, and 16 until 19 are not in use?
Bart
Changes
Bart
Hi Bart.
(ON ESXI )on NUC
bartbakels
PreviousNext
