bartbakels wrote:Mario,
First the easy part, The error, is an error when the http get call can not be exectuted, probably you have a wrong url in the configurations somewhere, check the http calls you make if they are all correct.
I'll double check this latter (related to a new issue I have right now with HTTP calls dissapearing, I explain bellow).
regarding your zones, i have an idea, but is it correct that you now have for example zone 1 until 15 in use and zone 20, and 16 until 19 are not in use?
Same thing happened with zone 11 (didn't detected this issue before as it's a flood sensor). I moved to zone 14 and it's working fine now.
The zones I have enrolled are 1, 2, 3, 5, 6, 8, 9, 10, 12, 13, 14, 18,19, 20 and 22.
New issue:
After moving sensor in zone 11 to zone 14, part of the configuration was lost (as another user reported): HTTP ON, HTTP OFF, Name and Sensor type.
I can see the information is still in the settings file at C:\Program Files\Visonic Driver\Settings
I suspect there is a problem with the settings file content so I sent you a PM with a link to it just in case you want to review it.
