Page 9 of 16
PostPosted: Thu Jul 28, 2016 10:59 am
by Mario from Spain
bartbakels wrote:Mario,
First the easy part, The error, is an error when the http get call can not be exectuted, probably you have a wrong url in the configurations somewhere, check the http calls you make if they are all correct.
I'll double check this latter (related to a new issue I have right now with HTTP calls dissapearing, I explain bellow).
regarding your zones, i have an idea, but is it correct that you now have for example zone 1 until 15 in use and zone 20, and 16 until 19 are not in use?
Same thing happened with zone 11 (didn't detected this issue before as it's a flood sensor). I moved to zone 14 and it's working fine now.
The zones I have enrolled are 1, 2, 3, 5, 6, 8, 9, 10, 12, 13, 14, 18,19, 20 and 22.
New issue:
After moving sensor in zone 11 to zone 14, part of the configuration was lost (as another user reported): HTTP ON, HTTP OFF, Name and Sensor type.
I can see the information is still in the settings file at C:\Program Files\Visonic Driver\Settings
I suspect there is a problem with the settings file content so I sent you a PM with a link to it just in case you want to review it.
PostPosted: Thu Jul 28, 2016 12:02 pm
by johnz
Hi Bart,
I lost that part of the configuration (http calls) again, no apparent reason.
Kind regards,
John
PostPosted: Thu Jul 28, 2016 12:05 pm
by bartbakels
strange... really no idea why, settings are only written on the save settings button on the settings screen. running more than one instance?
in addition did you change any zones, as Mario mentioned?
PostPosted: Thu Jul 28, 2016 12:07 pm
by bartbakels
New issue:
BTW, Mario can you cherck in your eventlog what event happened when the error occurred? zone X change I guess.
PostPosted: Thu Jul 28, 2016 2:32 pm
by johnz
bartbakels wrote:in addition did you change any zones, as Mario mentioned?
No, no changes to zones.
I cannot fully exclude the possibility that I had (briefly) running two instances (perhaps doubleclicking too fast), but I do not recall saving settings at that time (but cannot exclude the possibility that I did, in that case Imay have closed with the save button.
In other words, if it were for my problem alone, it may be better to see if the problem reoccurs
Kind regards,
John
PostPosted: Fri Jul 29, 2016 9:04 am
by Mario from Spain
New issue:
Very difficult as I don't know the exact time when config disappeared and there is a lot of information in the log.
PostPosted: Fri Jul 29, 2016 9:11 am
by bartbakels
just send me both logs, (eventlog.txt and errorlog.txt)
PostPosted: Sat Jul 30, 2016 11:48 am
by Mario from Spain
bartbakels wrote:just send me both logs, (eventlog.txt and errorlog.txt)
I just sent you an email with both files.
Thank you.
PostPosted: Sun Jul 31, 2016 9:39 am
by RudolfZTM
Hi Bart,
Thanx a lot for this nice application. I hope it will solve one of my problems migrating from HS2 to HS3. I am using an Alphatronics Wireless Interface for Visonic (AlphaVision NG). Does your application support this device as well? It is not (yet) in your list of supported devices. Do you have any ideas about possibilities to get it working with the AlphaVision?
Kind regards, Ruud
PostPosted: Mon Aug 01, 2016 8:14 am
by bartbakels
RudolfZTM wrote:Hi Bart,
Kind regards, Ruud
ruud,
No the alphatronic is an seperate interface, to get only the status of the sensors. My application is to directly interface the alarmpanel via rs-232. The alphatronic reciever is not needed anymore in that case.
regards
Bart
PostPosted: Mon Sep 05, 2016 8:37 pm
by Mario from Spain
Hi Bart.
Had you have a chance to look at the issue of the HTTP settings disappearing?
It happened again few days ago while I was in a trip.
I tried recovering the settings.ini file from a backup previous to the issue but the settings still down show.
PostPosted: Tue Sep 06, 2016 7:39 am
by bartbakels
Mario,
No I asked for another log and event log file, because i missed something. Regarding the settings, this is really, strange, i never had this issue, and the applications runs since the beginning, and at this moment 3 months without reboot :O.
However i have an idea why this can happen, the ini also holds the latest state of the sensors, so maybe its being written from 2 processes at a time. i will look into this after my vacation.
Bart
PostPosted: Tue Sep 06, 2016 2:24 pm
by PaulGF
First of all, I would like to congratulate to bartbakels for this fantastic application created to communicate with the Powermax alarms. I own a Powermax Pro and would like to try this application as it has very good looks, but the download links are down and you can not download.
I am new to this world of home automation but I am passionate about, so I hope I can contribute in any way I can whatever I can.
Greetings to all and grateful
Paul
PostPosted: Mon Sep 12, 2016 6:44 am
by bartbakels
PaulGF wrote:First of all, I would like to congratulate to bartbakels for this fantastic application created to communicate with the Powermax alarms. I own a Powermax Pro and would like to try this application as it has very good looks, but the download links are down and you can not download.
Paul
paul,
thanks, but i just checked the links, and they are working for me from an external location, so downloading should be no issue?
regards
PostPosted: Tue Sep 20, 2016 5:09 pm
by PaulGF
Hi, bartbakels
Yes, now is working, but 2 weeks ago not (at least for me). I'll try the application as soon I can.
Regards.
